odb83
Scoot Junior
Post by odb83 on Jun 13, 2022 10:24:09 GMT -5
I replace the right one easily but the left one I'm not sure how to do it is there a tutorial ? All the one i see are not like my prebug.
Post by aeroxbud on Jun 13, 2022 14:52:59 GMT -5
You just have to loosen the adjuster by the rear wheel. Then when you have enough slack in the cable the lever should undo, and pull out. There is a barrel shaped connection on the end of the cable the lever fits into. This pushes through the slot once you line up the cable with the gap.
odb83
Scoot Junior
Post by odb83 on Jun 14, 2022 8:48:28 GMT -5
You just have to loosen the adjuster by the rear wheel. Then when you have enough slack in the cable the lever should undo, and pull out. There is a barrel shaped connection on the end of the cable the lever fits into. This pushes through the slot once you line up the cable with the gap. It the second part that I'm not able to do , push the lock pin out.
Post by aeroxbud on Jun 14, 2022 14:44:38 GMT -5
You have to turn the lever till the cable lines up with the cut out. Then push the cable through.
