Post by impetus on Jun 18, 2022 0:24:20 GMT -5
hello,
i plan on buying a new Honda Ruckus. i have some hills to deal with between home, and where i'll be cruising. i've heard a great upgrade is the Dr. Pulley sliders in 5.5g. from what i understand, this raises the RPM to make more power while accelerating, and for climbing hills.
i'm wondering what this will do RPM wise when cruising on flat ground at moderate throttle/speeds 20-30 MPH.
thanks
Post by Zino on Jun 18, 2022 8:47:25 GMT -5
You will run at a notch higher rpms throughout the rpm range with lighter weights . Cvt Tuning Takes time and patience to dial it in for best performance for your weight and riding style I would get ahold of some tuning weights and a tach. Because you may find 6 grams work better than 5.5 grams for you. Here is a good over view www.49ccscoot.com/faq/whatweight.html
Post by impetus on Jun 18, 2022 17:45:21 GMT -5
many thanks Zino, i'll check it out. i do plan on getting a Tach for data.
Post by FrankenMech on Jun 18, 2022 21:42:39 GMT -5
There is no replacement for displacement. If you have hills go for 150cc or larger.
Post by impetus on Jun 18, 2022 22:25:43 GMT -5
There is no replacement for displacement. If you have hills go for 150cc or larger. an old adage that still holds true. the plan is to eventually get a KLX230.
for now a scooter that doesn't require a motorcycle license that gets 100+ MPG to get to work. i'll be taking a rider safety course to get my motorcycle license (again)
i wouldn't put a Chinese engine on the Ruckus. i was wondering about a Navi block though?
