Post by aeroxbud on Dec 13, 2022 22:55:14 GMT -5
Your cleaning and painting skills are exceptional. Looks like a great project restoring a classic. Thanks, I'm just trying to do things on a budget really. You can buy new panels, but they are expensive and this is very much a budget build. When it's finished I will use it as my commuter. My wife keeps on saying just get it done. It's only to ride to work. Don't worry about the looks!
Post by milly on Dec 14, 2022 3:32:48 GMT -5
With all the rust Paul did someone park it in the Solent for a while? 🙂
Post by aeroxbud on Dec 14, 2022 6:43:21 GMT -5
With all the rust Paul did someone park it in the Solent for a while? 🙂 It's done 16,500 miles, so been round the block a few times.
Post by aeroxbud on May 13, 2023 16:51:34 GMT -5
Well I wasn't having a lot of luck today. I wanted to check the condition of the oil seal, and oil pump drive. The stator was a nightmare to get off. Even with the proper puller. As you can see from the picture, it flared the end of the crank. The old seal is bad too.
Post by 190mech on May 13, 2023 17:14:49 GMT -5
Be thankful it came off! Get the threads cleaned up and a new seal,then its good...
Post by aeroxbud on May 13, 2023 17:22:48 GMT -5
Be thankful it came off! Get the threads cleaned up and a new seal,then its good... That's the idea. 👍 like you said, just glad it came off. Not sure what was going on. The nut was crazy tight too. Perhaps someone had been in there before with an impact?
Post by Lucass2T on May 15, 2023 7:54:43 GMT -5
Did you gave the flywheel a small tap with a hammer when it was under tension? Thats usually works pretty good.
Post by aeroxbud on May 15, 2023 14:12:24 GMT -5
Did you gave the flywheel a small tap with a hammer when it was under tension? Thats usually works pretty good. Yes I tried that. It wasn't coming off easily.I The nut was crazy tight too. I had to get a long breaker bar to remove it. Perhaps it was done up with a big impact gun?
Post by aeroxbud on Jun 11, 2023 18:57:48 GMT -5
The centre stand was was so badly worn, it hit the CVT cover. I ordered another stand which took three weeks to arrive. Then was too short. So ended cutting out the mounts and getting fresh metal welded in for £30. Drilling out the old mounting rod as it's cast into the cases was a nightmare.
