fxn
Scoot Junior
Post by fxn on Jul 5, 2022 13:15:55 GMT -5
trying to figure out why 50cc scoot doesnt have any lights or charging
stator ac reading while on yellow 20 - 60 jumping with throttle, white 20 - 60 jumping with throttle
rectifier dc - red 12.48v (should be reading 14-15v from what i have read)
ac - yellow 2.5 and white 11.3
Headlight wire loom has brown/white and 0v, blue 0v, white 2.8v and ground.
Does this mean the magneto and rectifier are working and no lights because of no active connection on wiring loom. And whould this point to why its also not chargin
Post by 190mech on Jul 6, 2022 18:00:29 GMT -5
UHH, Lots of 50cc scoots out there,,give us what the exact model is and maybe we can help...
fxn
Scoot Junior
Post by fxn on Jul 6, 2022 21:07:10 GMT -5
its a direct bike viper 50cc shoulda mentioned that )
Petro
Post by Petro on Jul 7, 2022 1:02:38 GMT -5
trying to figure out why 50cc scoot doesnt have any lights or charging stator ac reading while on yellow 20 - 60 jumping with throttle, white 20 - 60 jumping with throttle rectifier dc - red 12.48v (should be reading 14-15v from what i have read) ac - yellow 2.5 and white 11.3 Headlight wire loom has brown/white and 0v, blue 0v, white 2.8v and ground. Does this mean the magneto and rectifier are working and no lights because of no active connection on wiring loom. And whould this point to why its also not chargin If the wires is ok and You measured correct the rectifier is dead. Choose the same one when buying a new.
fxn
Scoot Junior
Post by fxn on Jul 7, 2022 14:22:13 GMT -5
Ive bought another one same as this and same it seems like its chargin but no lights either front or reg light. The front glows for a bit then stops
Post by jbjhillbilly on Jul 7, 2022 14:24:11 GMT -5
Are you running it on the stand, or riding? It won’t charge on the stand.
fxn
Scoot Junior
Post by fxn on Jul 7, 2022 18:32:20 GMT -5
its standing and i rev the engine via throttle but no indication it charges. I guess it makes sense to ride it and it should start charging but other videos show people standing the scoots and it readily charges at 14 to 15v without movin a bit.
I guess i can always recharge the battery or even use the kickstart but the lights are the main issue as without the battery i could still use the scoot but at night the lights are required.
Is there a way i can check for sure if the lights are AC or DC and if possible can i hardwire the lights to the battery ? or is that going to cause further issues ? thanks for the replies.
Petro
Post by Petro on Jul 8, 2022 1:47:04 GMT -5
trying to figure out why 50cc scoot doesnt have any lights or charging stator ac reading while on yellow 20 - 60 jumping with throttle, white 20 - 60 jumping with throttle rectifier dc - red 12.48v (should be reading 14-15v from what i have read) ac - yellow 2.5 and white 11.3 Headlight wire loom has brown/white and 0v, blue 0v, white 2.8v and ground. Does this mean the magneto and rectifier are working and no lights because of no active connection on wiring loom. And whould this point to why its also not chargin Reading this post again (and again) I realized that You (probably) measuring the white and the yellow twice, once at the stator harness and once at the rectifier? They should read the pretty much the same which telling me there must be a wire issue/short from the connection You measured 20-60v to the 2.5-11.3v. See if You temporary can replace white and yellow by taking two wires directly to the rectifier from the 20-60v point, that should tell You if those white and yellow is shorting.
fxn
Scoot Junior
Post by fxn on Jul 8, 2022 11:52:04 GMT -5
wait that sounds exactly like whats going on once i get home it out, so just hard wire the yellow and white from the stator to the rectifier
fxn
Scoot Junior
Post by fxn on Jul 8, 2022 18:11:33 GMT -5
i tried hard wiring the yellow and white strait from magneto to rectifier and its still the same, it seems its charging slowly but no lights at all what else can i do
Petro
Post by Petro on Jul 9, 2022 2:17:49 GMT -5
i tried hard wiring the yellow and white strait from magneto to rectifier and its still the same, it seems its charging slowly but no lights at all what else can i do Buy a new stator then and problem should be solved. I how ever do not understand it, Your AC is good on your current.
fxn
Scoot Junior
Post by fxn on Jul 9, 2022 18:15:23 GMT -5
i cant understand it too. it should be simple. Lights and charging carried out by stator in 2 wires yellow and white. FCurrent good from stator, current good on rectifier by hard wiring but charging at low volt and no lights. Il have to get a new magneto and check also il try check the light loom but cant find out the issue. Id say its shorting somewhere but either its in a place thats not accesible or in the loom itself. Il try with a new stator and let you know. thanks
Petro
Post by Petro on Jul 10, 2022 1:56:11 GMT -5
i cant understand it too. it should be simple. Lights and charging carried out by stator in 2 wires yellow and white. FCurrent good from stator, current good on rectifier by hard wiring but charging at low volt and no lights. Il have to get a new magneto and check also il try check the light loom but cant find out the issue. Id say its shorting somewhere but either its in a place thats not accesible or in the loom itself. Il try with a new stator and let you know. thanks This is what I call "the beauty of chinese engineering"... Nothing is wrong but it still doesn´t work.
Post by 190mech on Jul 10, 2022 4:09:38 GMT -5
What about your grounds?Is the engine grounded to the frame,headlight also,battery too??
fxn
Scoot Junior
Post by fxn on Jul 10, 2022 14:40:19 GMT -5
thats very accurate "nothins wrong with it, so whats the complaint, oh that nothing on works it"
But the entire thing is grounded by 2 wires bolted onto the frame which then diverts into what i can only explain as a thousand wires of grounds.
Put a new magneto on it ensured all wires were connected properly but its the same thing. All wires cleaned and plugged in. All wires go into same coloured wires via plug connecters. Have now tried 3 rectifiers and this is the 3rd magneto. It shows nowhere near 14v charging but id settle for it if it charges slowly even if you cant see it. But the lights no front lights at all, i dont even think the dash lights up and there is no reg light. Only thing it does is slightly glow as if its on then that fades away within seconds also.
