Post by keewayboi on Jul 22, 2022 11:15:37 GMT -5
I have 2 aprilia sr the other one is in pieces but had a carb and cdi the other one is mostly intact and has a ditech both morini motors i would like to put the cdi and carb on the ditech and just hardwire it but i dont have a clue about the 2 wire pickup or where ill get ac ignition power on the cdi
Post by 190mech on Jul 22, 2022 22:49:12 GMT -5
Post by keewayboi on Jul 23, 2022 14:02:13 GMT -5
Thanks for the answer but looks like those were for a minarelli the stator i have has 4 wires two for the voltage regulator and two from the pick up so how will i get them to 5 pin cdi ?
Post by keewayboi on Jul 23, 2022 14:04:04 GMT -5
Or atleast some of them were
Post by 190mech on Jul 23, 2022 15:07:57 GMT -5
Check out the TGB manual,they have Morini engines.. /www.49ccscoot.com/manuals/TGB_%202T_Service_Manual.pdf
Post by keewayboi on Jul 24, 2022 13:14:07 GMT -5
Post by keewayboi on Jul 24, 2022 13:15:35 GMT -5
okay heres the problem how will i connect them i have no idea and havent found anything useful in the guides sorry for the poorly made drawing
Post by 190mech on Jul 24, 2022 14:52:35 GMT -5
Post by keewayboi on Jul 24, 2022 15:18:01 GMT -5
Thanks for the answer i kinda figured that the other would be the ground only thing that questions me is the ac ignition power where does it come from
Post by 190mech on Jul 24, 2022 19:17:56 GMT -5
Which model do you have? I see 1E50,1E361,C364...
Post by keewayboi on Jul 25, 2022 8:28:13 GMT -5
2001 ditech
Post by keewayboi on Jul 25, 2022 8:48:17 GMT -5
And the carb is propably from ie50 and the ditech is c364
Post by keewayboi on Jul 25, 2022 8:52:39 GMT -5
It should be possible to be made i would look the carb morinis wiring but my friend cut some connector from them to his own project but the carb morini had 4 wire stator too
Post by keewayboi on Jul 25, 2022 9:18:15 GMT -5
I foubd the other sr stator the colors suggests that both pickup wires goes to cdi
Post by keewayboi on Jul 25, 2022 9:22:25 GMT -5
And one wire from the regulator goes to cdi
