Post by mk2rox on Jul 28, 2022 13:12:37 GMT -5
Alright i changed my pick up coil since it only gave 7omh so now it hits the powerband and works little bit better, changing the stator tomorrow with new backplate. lets see if this works
Post by mk2rox on Jul 28, 2022 13:13:14 GMT -5
i have 2 extra grounds between the engine and frame. Could my stator be broken? im still confused why it hit the powerband 1 time randomly Why do you think so? Have you previously to try to remove it with a sledgehammer? They very very rarely break, unless you've butchered it... i had water there and my friends had also randomly broken (stator)
Post by mk2rox on Jul 28, 2022 15:08:33 GMT -5
Does Yamaha bws backplate fit yamaha aerox?
Post by mk2rox on Jul 29, 2022 17:13:33 GMT -5
i have 2 extra grounds between the engine and frame. Could my stator be broken? im still confused why it hit the powerband 1 time randomly Why do you think so? Have you previously to try to remove it with a sledgehammer? They very very rarely break, unless you've butchered it... i changed cdi, stator and pick up coil, tuned pick up coil to 3mm, only bogs at full throttle
Post by Lucass2T on Jul 29, 2022 17:25:20 GMT -5
Did you change the plug? What heat range do you have in there?
Post by mk2rox on Jul 29, 2022 18:13:13 GMT -5
yes i have tried 1 br9es and 2 br9eg all do the same
Post by mk2rox on Jul 29, 2022 18:36:55 GMT -5
goes like 80-90 3/4 throttle and bogs a little, variator and carb need tuning but undriveable at full throttle just goes rrrrrrrrrrrrrrrrrr
