Post by tanto564 on Sept 2, 2022 13:40:16 GMT -5
I was cruising today and was coasting down a big hill. When I engaged my throttle my rear tire chirped and felt like it locked up for a second. Momentarily thought I was going over the bars. Anybody have any idea what this could have been? I can't make any sense of it.
Post by snaker on Sept 2, 2022 14:08:27 GMT -5
Sounds like you had let off the throttle and coasted down enough to disengage the clutch. At that point you are freewheeling and will coast as fast as the hill allows. When you add throttle, you bring up engine rpm's enough to reengage the clutch At that point it is the same as pulling in the clutch on a manual trans going downhill, downshifting to 1st, and letting out the clutch. Nothing wrong (if that was the case), just the characteristics of the machine.
Post by yambw’s on Sept 2, 2022 14:09:31 GMT -5
Last time I encountered this it was a soft seize.. could that be a possibility ?
Post by yambw’s on Sept 2, 2022 14:10:36 GMT -5
Or as above! That’s a good point
Post by tanto564 on Sept 2, 2022 14:34:36 GMT -5
Sounds like you had let off the throttle and coasted down enough to disengage the clutch. At that point you are freewheeling and will coast as fast as the hill allows. When you add throttle, you bring up engine rpm's enough to reengage the clutch At that point it is the same as pulling in the clutch on a manual trans going downhill, downshifting to 1st, and letting out the clutch. Nothing wrong (if that was the case), just the characteristics of the machine. Okay I figured it was something like this but I couldn't make sense of it since I have a centrifugal clutch not gears.
Post by yambw’s on Sept 2, 2022 14:42:51 GMT -5
You’d need to slow down to a few mph for it to disengage or lock up the rear wheel
Post by tanto564 on Sept 2, 2022 14:56:18 GMT -5
You’d need to slow down to a few mph for it to disengage or lock up the rear wheel Not sure how fast I was going when it happened but I know it was more than a few miles per hour
