Post by yambw’s on Oct 22, 2022 13:40:21 GMT -5
picked this up on Friday had 29miles on it, it runs like a sewing machine, Malossi mutivar on the way
Post by jbjhillbilly on Oct 22, 2022 13:59:09 GMT -5
That is very pretty!
Post by aeroxbud on Oct 22, 2022 14:53:30 GMT -5
Nice find. They go quite well once a variator is fitted. Might even get 45mph. 👍
Post by yambw’s on Oct 22, 2022 15:01:35 GMT -5
Nice find. They go quite well once a variator is fitted. Might even get 45mph. 👍 Let’s hope so I’ll report back! needs a full service, has 10 year old fuel In it! Runs and Rides just fine would you believe
Post by titiz67 on Oct 22, 2022 15:51:21 GMT -5
Hello, was it in concession all this time?
Post by yambw’s on Oct 23, 2022 4:55:06 GMT -5
It was first purchased by a lady who sadly died 3 weeks later and stood for 5years then the guy I got it from rode it a hand full of times over the last 5 years
Post by aeroxbud on Oct 25, 2022 5:33:17 GMT -5
I had a look but couldn't find a level for it. On my previous motorcycles I have played with the oil level to make it stiffer. We used to do it a lot in the 80's. The spec is a guide, it's not going to matter if it's a little out. You probably wouldn't want it as stiff as the bigger bike. Perhaps go 50ML? 🙈 If it's too stiff they do tools to adjust the level. Basically a big syringe and a tube.
Interestingly my aerox wasn't leaking, but when I changed the oil. Both forks had a different amount in. Must of been like that from new. 🤔
Post by yambw’s on Oct 25, 2022 6:11:44 GMT -5
I had a look but couldn't find a level for it. On my previous motorcycles I have played with the oil level to make it stiffer. We used to do it a lot in the 80's. The spec is a guide, it's not going to matter if it's a little out. You probably wouldn't want it as stiff as the bigger bike. Perhaps go 50ML? 🙈 If it's too stiff they do tools to adjust the level. Basically a big syringe and a tube. Interestingly my aerox wasn't leaking, but when I changed the oil. Both forks had a different amount in. Must of been like that from new. 🤔 Appreciate that Aeroxbud 👍
Post by 190mech on Oct 27, 2022 3:30:20 GMT -5
A general rule for damper rod type fork oil level is about 20mm above the top of the damper rod with the fork extended and no spring installed yet..
Post by yambw’s on Oct 27, 2022 12:49:27 GMT -5
A general rule for damper rod type fork oil level is about 20mm above the top of the damper rod with the fork extended and no spring installed yet.. Ok thanks for that I’ll give it ago and see what it equates to in ML
Post by geoffh on Oct 28, 2022 14:48:36 GMT -5
Congrats on the find of the year a real unicorn these days,any numbers before you mod it to death??
Post by yambw’s on Oct 28, 2022 15:05:30 GMT -5
Congrats on the find of the year a real unicorn these days,any numbers before you mod it to death?? Geoff thanks Geoff! Numbers? I won’t mod it to death 😂 I’m not going to start putting mallossi stickers on it, just some tasteful mods! Probably the only nsc that’s not being used for dropping pizzas tho lol
Post by geoffh on Oct 29, 2022 6:32:35 GMT -5
I didn't,t take notes or even sat Nav my speed when I started to mod my scoot(my bad) I just thought it might be an opportunity for you to document the changes and results to a (presumed)stock scooter.
Post by yambw’s on Oct 29, 2022 13:58:10 GMT -5
I didn't,t take notes or even sat Nav my speed when I started to mod my scoot(my bad) I just thought it might be an opportunity for you to document the changes and results to a (presumed)stock scooter. Geoff 29mph firm I’m just in the garage now finish up the forks then going to fit the mutivar, what’s the top speed on 4stroke Peugeot?
Post by aeroxbud on Oct 29, 2022 14:51:46 GMT -5
Are you going to change the tyres at some point? Standing for so long they would of gone quite hard now.
