Post by milly on Oct 23, 2022 11:29:56 GMT -5
Today I started the build project using a old Vespa ET4 and engine from a Piaggio skipper 125. I will be putting a 150 cylinder kit I have. At present fitted the Vespa GTS 12" front wheel to replace the 10" and larger disc and caliper and hub from the GTS. Now found et forks won't fit the caliper so awaiting GTS forks to arrive.
