Post by coachhejl on Dec 24, 2022 22:52:33 GMT -5
If I'm buying a kit with valves already installed...does it matter if I get 64 or 69?
If I get just the cylinder and piston kit...I can use my own stock head right?
Post by aeroxbud on Dec 25, 2022 6:14:58 GMT -5
Brent explained it well here.
Post by GrumpyUnk on Jan 5, 2023 10:53:56 GMT -5
If you do not get another head, you can use the original. I would suggest using a composition head gasket as 1) its thickness compared to steel will lower the CR just a bit, and 2) the composition gasket will conform just a bit better to the surface of the original cylinder head. Stamped sheet metal head gaskets depend more on the condition of the cylinder head and cylinder being in perfect pristine condition. A composition will conform just a bit better to any irregularities in the surface, and still has a 'fire ring' facing the combustion chamber. tom
br4inl3ss
mentally somewhere else
Post by br4inl3ss on Jan 7, 2023 12:26:44 GMT -5
If I'm buying a kit with valves already installed...does it matter if I get 64 or 69? If I get just the cylinder and piston kit...I can use my own stock head right? those come without rocker arm. you must use the proper rocker arm. if you plan to re-use your rocker arm, you need to get a head with the same lenght valve as your. if you change the rocker arm at the same time, you pick according to the head you're getting.
