Post by coachhejl on Jan 3, 2023 18:15:20 GMT -5
I bought a Scootstar Roguestar 50. Has the typical 49cc 139qmb.
I bought a plain 72cc big bore kit and will put it in, next couple weeks I will put it in.
I have several different roller weights to tun the cvt...as well as a little better variator.
Jet kit 78-105 I think.
Anyways...I want to basically upgrade the top end and then as minimal as possible everything else to keep it reliable and easy to tune.
After installing the BBK, what are the secondary upgrades/tuning upgrades you would do to get the most bang for buck and to keep bike reliable and easy to tweak after that?
Stock carb is a Deni PD18j (made in japan). It seems higher quality than the $25-$30 ones you can get on ebay and amazon.
My current rollers are 6g, which to me seems a bit heavy for a stock 49cc 4 cycle.
Anyways, just looking for opinions.
Post by FrankenMech on Jan 3, 2023 20:24:41 GMT -5
Try one thing at a time.
Post by Zino on Jan 4, 2023 9:02:38 GMT -5
First law of Scooter tuning change one thing at a time. 2 reasons for this If there is a problem you can retrace your steps . You enjoy and feel the differnece of each piece of your hard work .
claydoh
Post by claydoh on Jan 4, 2023 9:54:36 GMT -5
I will third what Zino and Frank are saying, One change at a time. Try that change for a bit before going to the next thing.
As to roller weights, that is almost purely dependent on your personal preferences. I myself always seem to end up back at the stock 6g, even after a variator upgrade. *You* might like something different, or find one that works better for your usage.
Post by coachhejl on Jan 4, 2023 16:11:53 GMT -5
So 6g is quite common as a stock size? I will third what Zino and Frank are saying, One change at a time. Try that change for a bit before going to the next thing. As to roller weights, that is almost purely dependent on your personal preferences. I myself always seem to end up back at the stock 6g, even after a variator upgrade. *You* might like something different, or find one that works better for your usage.
claydoh
Post by claydoh on Jan 4, 2023 16:51:26 GMT -5
So 6g is quite common as a stock size? As far as I have seen on my three different scooters, they have all been 6g. One new, one used/unmodified, and one used/slightly modified. All 49cc qmb139's
Post by GrumpyUnk on Jan 5, 2023 10:37:04 GMT -5
One important bit to consider when fiddling with weights is the weight of the operator. The additional weight of a driver is a significant portion of the heft the scooter has to haul around, much more so in a small vehicle. Thusly, suggested weights for the variator will give different results based on operator weight. FWIW. Stated only to remove the surprise when things come out differently when testing. tom
