Post by coachhejl on Jan 8, 2023 12:24:50 GMT -5
Is disabling the oil injection easy to do on a roughhouse?
I have done it on a Vento Triton, but may be upgrading to a roughhouse.
Any and all info y'all could give, would be hugely appreciated.
Thanks!
Post by Zino on Jan 8, 2023 19:56:46 GMT -5
Why disable it ? It is very reliable up to 11k rpms .
Unless you are building a race motor its better to leave as is .
Post by coachhejl on Jan 8, 2023 22:31:27 GMT -5
Was curious. Even if you go 70cc? Still sufficient? Why disable it ? It is very reliable up to 11k rpms . Unless you are building a race motor its better to leave as is .
Post by Zino on Jan 8, 2023 22:33:26 GMT -5
My build is 70 cc with stock pump I run stock pump on all my 70 cc non race builds
