Post by FrankenMech on Feb 3, 2023 21:44:31 GMT -5
I can not even work a 'smart phone' so you are way beyond me. I be just a dumb desktop operator struggling with a new keyboard. I still can't typer worth shit, never could. I got up to a whole ~20+ words per minute in high school. My father could type 90 correct words per minute on a manual typewriter, sounded like a machine gun. Someone with a smart phone should be able to tell you what you are doing worng I just noticed the double text recently. Hmmm, the exhaust nuts on my 2012 Dong Fang trike were enclosed, long acorn nuts. I also use anti-seize on them. If I didn't have acorn nuts I would use stainless steel or brass nuts with anti-sieze or even SS studs with brass nuts. I must confess I HATE sticking steel fasteners into aluminuminum especially in high heat applications.
Post by milly on Feb 4, 2023 10:36:59 GMT -5
Well new exhaust system ordered having a break from doing the rear brake and removing the wheel till later now carb, fuel changed tank drained and it's running.
Post by milly on Feb 4, 2023 16:32:18 GMT -5
Post by FrankenMech on Feb 4, 2023 20:55:52 GMT -5
Beware of Murphy.
Post by milly on Feb 5, 2023 15:10:53 GMT -5
Buttoned up the front panels today and lubed the starter switch so is no longer sticking. New tyre ordered, done for now till part's arrive other than freeing off brake cam with a bit of heat.
Post by FrankenMech on Feb 5, 2023 16:22:40 GMT -5
Melting a bit of candle wax into the brake cam with a tiny amount of heat may help. Once removed a bit of polishing and anti-seize may help. Steel does not abide well with Aluminuminiumum. Do you really need an "L" sticker?
Post by milly on Feb 6, 2023 10:48:41 GMT -5
Wow tried out the hot air gun on plastic today not expecting much difference. Impressed I am.
Post by milly on Feb 7, 2023 16:00:06 GMT -5
New Technigas silent pro. Not bad for £97 and a good fit too. New tyre arrives tomorrow.
sinfull
Post by sinfull on Feb 7, 2023 18:14:14 GMT -5
Great job so far 👏 👍 bike is starting to look pretty nice. Should be a nice bike to ride when you get done.
Post by milly on Feb 8, 2023 17:09:04 GMT -5
Post by aeroxbud on Feb 9, 2023 6:10:36 GMT -5
That's come up nicely Milly 👍👍
Post by milly on Feb 9, 2023 7:09:35 GMT -5
That's come up nicely Milly 👍👍 Thank you Paul, seems a shame to sell it. But it's either that or the Vespa.
Post by milly on Feb 9, 2023 16:30:16 GMT -5
Road test went ok but bit squirrely on the front end so if tyre's got to come off may as well play safe and put a new one on there.
Post by FrankenMech on Feb 9, 2023 17:11:49 GMT -5
There may be other things making it squirrely.
Post by milly on Feb 10, 2023 16:21:01 GMT -5
There may be other things making it squirrely. Tyre was low on pressure rest of steering appears ok. But now you reminded me thank you I shall give it a thorough check over when ramp free next week and make sure of wheel alignment too.
