I picked up a Drive Belt sootertuning
it's a Mitsuboshi Hyosung 772x16.5mm
real size is 761x16.2 wide by 8mm deep
Model: VC30920
and was the last one they had in-stock
I installed the 107mm NYC rear pulley and 107mm Mallossi Fly clutch with a yellow spring
these pictures are the 1st ride 12.5 miles so I gotta break it in more yet
I'm getting full travel on the rear pulley with 3mm left outside edge
the variator has 2.8mm shims at the boss and belt is riding down 10mm from the the boss
I'm hoping as the belt wears a little I'll be able to take some shims out and give the lock nut more threads
I didn't use any shims against the starter clutch
it's slow on take off so I'm thinking of trying to split the shims and put half of them against the starter clutch
I don't now if it'll make any difference
I have 5.2g and 5.7g rollers, speed is good still 50ish mph at 9800rpm and it has more to go it's like there's no end
I don't wanna blow it up
I've gotta get the carb sorted out now
running at 40mph it's rpm is 9100 and the temp at a 287f
at that speed it sometimes almost feels like it's running out of gas till I open it up again
and it wont start when it's warmed up unless I give it gas
gas mileage is terrible I can almost see the gauge going down so I just made it back before bending the empty needle
1/2 tank for 12.5 miles so now I'm looking at the carb and float needle setup
the plug BR9HS doesn't look to bad maybe a bit rich (to me anyways) the 92 main is still in
and the mix is 50-1 gas is Mid grade 89 and 5% Ethernol
one side of the plug is darker than the other
if you guys can give some advice that would be Awesome Thx
