Post by keewayboi on Jan 13, 2023 15:29:46 GMT -5
is it possible and if it is how? im not very good in electrical stuff
Post by keewayboi on Jan 13, 2023 15:30:20 GMT -5
wrong pic
Post by keewayboi on Jan 13, 2023 15:31:59 GMT -5
Post by aeroxbud on Jan 13, 2023 15:44:56 GMT -5
You need to check the resistance of the coil with a multimeter. It should give you a spec for a good coil in the manual.
Post by keewayboi on Jan 13, 2023 15:49:47 GMT -5
it doesnt generat strong enough spark i had a new coil that had a good spark but i cant find it anymore
Post by aeroxbud on Jan 13, 2023 15:56:47 GMT -5
There are a couple of Keeway manuals in the library you could compare your coil to.
Post by snaker on Jan 14, 2023 11:09:52 GMT -5
The photo doesn't show the spark plug wire Is that terminal dirty or loose? You can buy a length of plug wire and a new boot end Or you could take it off the good setup and swap, although you risk ending up with two broke setups
