Post by coachhejl on Jan 25, 2023 18:57:50 GMT -5
Is this a gy6 engine? To where I could use big bore kit made for gy6 139qmb?
And all other parts?
Post by GrumpyUnk on Jan 27, 2023 8:53:33 GMT -5
I do not know individual brands, and the brands are likely product of a few main corporations. That said, differentiation between them is difficult. To determine the engine design, look at the serial number plate where information is inscribed into the metal of the engine block. The model is usually stamped/lasered into the surface. You can also look at the emissions label and the label indicating factory and other tune up information. Most will indicate the engine model number somewhere, along with the displacement, date of manufacture, weight, tire size(s), tire pressure(s), oil capacity and viscosity, idle speed, and valve clearance. tom
claydoh
Post by claydoh on Jan 27, 2023 19:11:04 GMT -5
Post by dexameth on Feb 4, 2023 7:26:55 GMT -5
I'm a Genuine dealer. Yes, that model is your typical 139QMB engine. The scooters come restricted from the factory, if you didn't know. They have the CDI restriction linked to the clutch bell limiting output speed. Simply unplug the bullet connector at the CDI. The carbs are lean, install a #82 main jet and they have MUCH more "punch".
Amazon cheapo big bore kits will leave you with more of a headache than spending a bit more on quality kits, like Naraku or SSP-G or Airsal etc.
Post by coachhejl on Feb 4, 2023 11:33:45 GMT -5
What do you mean restricted at the clutch bell? I'm a Genuine dealer. Yes, that model is your typical 139QMB engine. The scooters come restricted from the factory, if you didn't know. They have the CDI restriction linked to the clutch bell limiting output speed. Simply unplug the bullet connector at the CDI. The carbs are lean, install a #82 main jet and they have MUCH more "punch". Amazon cheapo big bore kits will leave you with more of a headache than spending a bit more on quality kits, like Naraku or SSP-G or Airsal etc.
Post by GrumpyUnk on Feb 5, 2023 12:45:29 GMT -5
I have seen some with a rpm sensor mounted near the clutch bell. It senses the rpm of the input shaft to the final drive gearbox. If the rpm sensed is above what the speed limitation allows, the signal to the CDI will make the CDI quit with the sparking already. IOW, it is a rev limiter. Unpluggind allows the CDI to continue to functino above the factory installed rev limit of the output gearing. Some variators use a cylinder on the crankshaft that keeps the two sides of the variator from coming together beyond a certain position. Limiting the travel essentially limits the gear ratio produced going higher than the maker wants it to, and thus limits final drive ratio. tom
Post by FrankenMech on Feb 5, 2023 14:28:46 GMT -5
Most state laws limit 50cc scooters to a 30MPH top speed unless going downhill or with the wind at your back. Some EFI systems without a carb limit speed and will not function without the speed sensor.
