Post by japanes626 on Jan 26, 2023 8:18:33 GMT -5
How many splines does a stubby gy6 rear axle have? Most gy6 rear axle here have 18 splines that mount to the rear wheel Hoping to verify a 19 spline axle exists, as 18 spline rear hubs have been phased out here since 2016.
Post by sToRm on Jan 28, 2023 7:58:26 GMT -5
The short axle and hub i use on a GY6 swapped Ruckus has 19 splines. The motor is a 150cc.
Post by GrumpyUnk on Jan 28, 2023 8:37:02 GMT -5
The output shaft from the final drive gearbox is separate from the gear, so could be replaced with a different shaft without need to press a gear on or off. Could be that a standardization was done for the output shaft to make the tooling and machinery compatible between all engine sizes, all then producing the same spline count. tom
