Sure I know a guy that ruined an engine with a 100cc BBK......cause after running it out of oil in the stock 50cc configuration with 4,200 miles on it....the top end seized..so he replaced it with a BBK which only gave him about 300 miles before the engine was junk.... But hell....when you run a stock engine dry of oil till it locks up....you can rest assured the piston and rings were not the only engine component that was compromised and prematurely worn.
a very valid point - engines do run better with oil in them!!!
on a recent endurance run with 3 of the peds running 139qmb motors, 2 with 70cc bbk & mine with the 83, we were all having to check & top up the oil at every fuel stop.
when you consider the small amount of lube in these motors, it's easy to see how people kill them so quick.
i think they fit the bbk then think cos its 'a new engine' they dont need to do anything to it, when in reality it'll probably burn more oil with the new kit, at least until it's bedded in nice.
also on mine, i noticed that after just 2-300 miles it was smoking quite a bit, so i stripped it at the roadside to find both rings stuck solid in their grooves.
this also happened to one of the 70 kits.
it's easy to fix with a bit of patience, but this coud be another factor in premature failure... the fact that these kits are made so cheap there is obviousy a compromise in quality...
just something you may need to check after a brief run-in
and also the valve stem seals.... the new ones i got in my kit were poor quality and were contributing to high oil consumption - i ended up fitting gen honda spacy seals instead.
there is a temptation to think, hey, this thing is well faster than it used to be, so they screw the nackers off them everywhere... run it dry in the process then moan when they fail lol.
so imo its not the bbk that fails, its the lack of basic maintenance after fitting the kit that lets so many down.
also bear in mind a lot of the people killing their peds are young kids with not a lot of experience in the workings of a motor!
