Zuma / BW'S 2002 Build Sept 16, 2023 15:08:50 GMT -5 via mobile aeroxbud likes this Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by scootbydoo on Sept 16, 2023 15:08:50 GMT -5 Yeah, I'll look at Polini CP and DellOrto carbs.
Zuma / BW'S 2002 Build Sept 16, 2023 15:52:12 GMT -5 aeroxbud likes this Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by Zino on Sept 16, 2023 15:52:12 GMT -5 No knock off carbs .You will need a new throttle cable for the aftermarket carbsYou can make the current throttle tube work or get a new one they also need a manual choke cable .17.5 dellortowww.scootertuning.ca/en/carburettors-sport-midrace/5169-carburettor-dellorto-phbn-ls-175mm-1000000000447.html Would be what I would get for your level of build it will provide more power and still have good throttle response .You will need jets in the high 80s low 90s with this carb with stock air boxA 19mm dellortowww.scootertuning.ca/en/carburettors-sport-midrace/5004-carburettor-stage6-dellorto-racing-black-edition-mkii-19mm-4051272274947.html would also work but throttle response will probably be worse than the smaller carbwith stock air box you will need jets in the low 80'sBoth of these work with stock air box
