Post by macoryx on Sept 14, 2023 17:25:26 GMT -5
Consideration, when you fit the drive belt make sure it is pushed deep into the rear pulley,this will ensure that it is loose/free at the variator when tightening the nut up ,buy a variator locking tool to do this job and don't,t forget that broken bush Geoff Can I use my impact driver on it?
Post by geoffh on Sept 15, 2023 15:12:57 GMT -5
Using the impact driver is a no no,take the time to torque the nut properly and check the belt is loose before starting the scoot.
Post by GrumpyUnk on Sept 16, 2023 13:01:08 GMT -5
tried the crankshaft line. got me to 'super offers' 'your guide to the best products'
not good. no crankshaft. not gonna bother with others. the 'link squsher' you used lied to you. I think. mebbe use long links? i dunno. tired of bleeping hackers. trying to not use the words I feel. Muy esposza got phished. got all her cc info. Google gave muitiple links to etsy.com 'customer service' links ... phish here phishsy phishy phishy. and she got fishes. locked 3 credit rps sites... but she had MY google id/pw. got my amazon pw... and tried to go to town. so, shorty links that send me to mars... no thanks. tom
Post by macoryx on Sept 16, 2023 15:54:20 GMT -5
My man, I’m a cybersecurity major so I know how they get you, I promise you I’m not up to anything shady. I copied it straight from Amazon and it gave me that shortened link. Whether or not you want to open it is completely your call. A good rule of thumb is to follow the redirects of any URL you are given. You can do this with a website called WhereGoes, but there are others like it. Try it on a trusted shortened link so you can know how it works. Feel free to use the links I sent you with that site and you will see they lead to Amazon. I had that weird super offers thing happen to me too and I believe the link should be updated now.
Post by macoryx on Sept 16, 2023 15:54:38 GMT -5
Post by GrumpyUnk on Sept 17, 2023 12:23:05 GMT -5
went to the amazon link for the crankshaft. Unless they posted in error, I would not want an aluminum crankshaft. I do not think it would work, though I could be wrong. I think they made a mistake. Is that the correct number of teeth for the oil npump? tom
Post by macoryx on Sept 17, 2023 12:50:15 GMT -5
went to the amazon link for the crankshaft. Unless they posted in error, I would not want an aluminum crankshaft. I do not think it would work, though I could be wrong. I think they made a mistake. Is that the correct number of teeth for the oil npump? tom I believe it should be correct, yeah. I didn’t check before hand but I’m pretty sure most of the icebears use that configuration.
Post by GrumpyUnk on Sept 18, 2023 6:59:22 GMT -5
I am not familiar with the brand of CVT belt you linked to on 'zon. My take has been that you want to get a name brand belt if you want consistent performance and longevity. I have heard Gates brand are good. i had other brand names in my head, but the names must have fallen out somewhere. If you have experience with that brand and like it, by all means continue, but I expect most would suggest a brand name instead. Bando. Gates. blank... tom
Post by macoryx on Sept 18, 2023 18:07:01 GMT -5
I am not familiar with the brand of CVT belt you linked to on 'zon. My take has been that you want to get a name brand belt if you want consistent performance and longevity. I have heard Gates brand are good. i had other brand names in my head, but the names must have fallen out somewhere. If you have experience with that brand and like it, by all means continue, but I expect most would suggest a brand name instead. Bando. Gates. blank... tom It ended up being the wrong crankshaft, new one will be here tomorrow... that's the annoying part with these Chinese scooters, you can't find specs anywhere.
Post by FrankenMech on Sept 18, 2023 21:27:18 GMT -5
Post by macoryx on Sept 18, 2023 21:31:19 GMT -5
Gotcha. Do you know where I could find a diagram for the crankcase bolts? I am forgetting where the 4 long ones go as to where the 4 shorter ones go.
Post by FrankenMech on Sept 19, 2023 0:11:31 GMT -5
Post by GrumpyUnk on Sept 19, 2023 10:09:00 GMT -5
Gotcha. Do you know where I could find a diagram for the crankcase bolts? I am forgetting where the 4 long ones go as to where the 4 shorter ones go. When re-assembling things with multiple sizes originally installed, most times you can figure which go where by putting the two parts together, and then fitting the bolts to the holes. The amount of bolt that remains exposed should be approximately the same for all bolts as when seated fully the will all press on the parts being assembled with about the same force. Just a glance should show bolts that are kinda short and those that are way longer than the others. Swap them until all bolts have about the same exposure. It's a lot more fun when installing water(coolant) pumps on the front end of an in-place engine as some of the bolts may need a sealant to keep the coolant inside and not seeping past the threads. And you can see them readily. And they are dirty and rusty. And you are trying to reach over a fender in the cold, going uphill both ways. Anyway, just setting the bolts into the holes may give enough information for an educated guess. Lots better than stripping threads when a too-short bolt is used or breaking a too-long bolt trying to get it to run down and do something. tom
Post by FrankenMech on Sept 19, 2023 19:35:41 GMT -5
Very smart Tom. I usually resorted to punching holes in cardboard of some type to show the arrangement. I have also used a scribe to mark locations on the parts. I love the comment about fenders, cold, and uphill both ways...
I have also seen the starter relay stick and keep the Bendix engaged which can make a mess.
Post by GrumpyUnk on Sept 20, 2023 7:28:26 GMT -5
A stuck relay can be 'interesting', until the starter starts to smoke... then it becomes VERY interesting. Only cure I found the one or two times it happened was to get a terminal off the battery post as quickly as I could. So far, nothing has caught fire. More difficult on the little machines that tend to make this site popular. With the seat bucket down, bolted, screwed, etc, and the battery likely hidden under a screwed-on cover, I don't know what I would do should that happen. Could be there is not enough battery capacity to cook a starter motor enough to make it burst into flames. I know I do not carry a Philips to be able to get to anything should it happen. Yes, Cheerios boxes work for punched hole retainers. They also work for water pump gaskets if you are decent with a scissors and a sharp knife. The tan 'oaktag' folders and hanging folders also work for that purpose. I actually bought a set of hold punches. Very similar to cold chisels, but with a round cutting end, each one for specific sized holes. The punches, a scissors and some gasket paper and a lot can be made in the garage when the store is closed or miles away. tom
