you must have a 2008 -2011 zuma with the restricted carb
Advantages to 2008 best gearing of the bug eye
disadvantages nonadjustable carb
I used the vino pilot jet to richen up to make up for the non adjustable needle
vino pilot jet 46 5BM-14353-23-00 is the yamaha part number
Leave airbox as is
It runs best like that
You just need to seal the hole that came from the pollution control crap that went to the stock pipe
Variator
Try all 5.5 then try all 5's one will feel best and give you best Top speed .
For setting variator weights
Do high speed runs on the same stretch of road
via gps on your phone track top speed and responsiveness
run all stock weights for a baseline male notes like this
6 grams 40 mph sluggish on throttle off throttle
5.5 grams 40 mph spunky on and off throttle
5 grams 39 mph spunky on and off throttle
You also can test the in between weights by running half and half for balance
6/5/6/5/6/5
I will bet the 5.5 are the ones that work best
you have a restricted carb here is the fix
www.zumasrus.com/zdox/ztip6.html
