Post by Fox on Jan 10, 2012 1:20:24 GMT -5
I work on scoots for a living so anything I can do to save time is great. The single most time saving tool I have in my arsenal is a cheap $5 drill bit socket adapter set from Harbor Freight. It allows you to spin bolts at a rate that is humanly impossible. Coupled with a Phillips head bit you can strip down and reassemble a scooter in half the time it takes using hand tools. I strongly suggest everyone get a set of them. Like I said I got mine at HF but if you don't have one close by then you can get them on-line. compare.ebay.com/like/160639012525?var=lv<yp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y I also have a set of these cause they save time coupled with a drill or ratchet. Happy Wrenching!
Tweak09
2011 Yamaha Zuma
Post by Tweak09 on Jan 10, 2012 3:58:38 GMT -5
Allen Socket sets are a dream!!! I changed all the phillips screws over to allens on my scooter. (due to getting in a rush and stripping screws of with the drill) Those sockets save so much time instead of using a allen wrench manually.
Post by martyd on Dec 21, 2012 22:35:16 GMT -5
With these would the the drill be able to take off the variator nut ?
Post by aeroxbud on Dec 22, 2012 20:00:03 GMT -5
bare
Post by bare on Dec 22, 2012 22:17:40 GMT -5
Impact gun is a mixed blessing on these, I've discovered. On Yama BWS at least the Crank/variator nut and clutch nut are of such Garbage Quality that even My cheap and weak Electric Impact gun chews the hell out of the nuts ..almost instantly. These then need replacing after the second Gun use. This is surprising as well as annoying given I've been fiddling with Yamahas since '73 and this NEVER happens with their Motorcyle parts. Clearly these Yama scoots are assembled in some 3rd world Line using abysmal quality metal fasteners.
Post by shakerdriver on Dec 23, 2012 0:57:57 GMT -5
I just received a tool I bought from racing planet that I think is cool and is gonna be real handy in the long run. It holds the variator, clutch bell, and removes the big ass contra spring nut. Its a really good tool to have for $39 shipped. Sent from my Nexus S 4G using proboards Attachments:
Post by aeroxbud on Dec 24, 2012 20:18:50 GMT -5
That looks a good tool shakedriver. Never seen one like that before, i had to buy each tool on it's own
Post by jmkjr72 on Dec 24, 2012 21:01:45 GMT -5
Impact gun is a mixed blessing on these, I've discovered. On Yama BWS at least the Crank/variator nut and clutch nut are of such Garbage Quality that even My cheap and weak Electric Impact gun chews the hell out of the nuts ..almost instantly. These then need replacing after the second Gun use. This is surprising as well as annoying given I've been fiddling with Yamahas since '73 and this NEVER happens with their Motorcyle parts. Clearly these Yama scoots are assembled in some 3rd world Line using abysmal quality metal fasteners. you are the only one i have heard with that problem the nuts on my zuma have been on and off at leats a dozen times and they are still the oem nuts now the screws and the bolts that hold the belt cover on are a diffrent story
Post by Fox on Dec 24, 2012 23:05:43 GMT -5
I just received a tool I bought from racing planet that I think is cool and is gonna be real handy in the long run. It holds the variator, clutch bell, and removes the big ass contra spring nut. Its a really good tool to have for $39 shipped. Sent from my Nexus S 4G using proboards Interesting. Post pics here when you use it.
Post by Fox on Dec 24, 2012 23:08:31 GMT -5
Impact gun is a mixed blessing on these, I've discovered. On Yama BWS at least the Crank/variator nut and clutch nut are of such Garbage Quality that even My cheap and weak Electric Impact gun chews the hell out of the nuts ..almost instantly. These then need replacing after the second Gun use. This is surprising as well as annoying given I've been fiddling with Yamahas since '73 and this NEVER happens with their Motorcyle parts. Clearly these Yama scoots are assembled in some 3rd world Line using abysmal quality metal fasteners. you are the only one i have heard with that problem the nuts on my zuma have been on and off at leats a dozen times and they are still the oem nuts now the screws and the bolts that hold the belt cover on are a diffrent story The cheap sockets that come with the 12 volt tire impacts crack easily. My 17mm cracked on a job and I had to run and buy another one. It rounded the nut a little but not bad. I bought a few good quality sockets for it eventually and never had a problem since.
Post by shakerdriver on Jan 30, 2013 10:11:16 GMT -5
I finally had a chance to use my 3n1 tool and it works like a charm. It can hold the crank via the variator kick start paw while loosening the flywheel nut also so its really a 4n1 tool IMO. Its definitely a tool worth having in the toolbox.
Post by aznatama on Mar 17, 2013 15:05:16 GMT -5
Can you show how you secured it to the castlenut? I have the buzzetti tool which is similar, but there's no way to secure it, so it won't work. Seems like this tool will also do the same thing.
Post by highsocietyscooter,cpi70cc on Mar 19, 2013 16:16:02 GMT -5
i always recommend a flywheel puller i have broke a couple stators and a crankcase as a rooky
Post by ʇwiƨtɘdburnout on Mar 19, 2013 21:10:45 GMT -5
I think I'm going to get these, thanks for the tip. I will just pick up the cordless impact while I am at HF and use it with the variator lock I just purchased.
Post by Goosey on Mar 20, 2013 14:45:12 GMT -5
The beauty of the impact is you don't have to use anything to lock up the variator, or wheel, or clutch,you get the picture.
