Post by aeroxbud on Jun 12, 2024 11:00:50 GMT -5
The head lights won't work until the scooter is running, as it's an AC system. The horn should work though. It's such a long time since I've worked on one, but the starter relay is usually not far from the battery. If you follow the wire from the starting motor it will be there.
palehorse
Off grid in Idaho
Post by palehorse on Jun 12, 2024 23:19:32 GMT -5
So stupid, DOH! The shutoff switch was off. I just didnt notice. Solved the problem.
palehorse
Off grid in Idaho
Post by palehorse on Jun 12, 2024 23:27:10 GMT -5
Thanks everyone for the help.
Post by aeroxbud on Jun 13, 2024 3:50:23 GMT -5
You wouldn't be the first to make that mistake. Glad you found the problem.
pili
Post by pili on Jun 13, 2024 9:47:45 GMT -5
So stupid, DOH! The shutoff switch was off. I just didnt notice. Solved the problem. I've been there. I don't use the kill switch to stop the engine but sometimes I switch it by accident when cleaning or working on it.
