Post by teddy554 on Jan 12, 2012 17:44:17 GMT -5
i have this r3 zip that just dies at full throttle or will just bogg down to low rpms from full throttle. i have change the clutch, clean the carb even used another carb same results this is the video
vvtr
Post by vvtr on Jan 12, 2012 17:49:38 GMT -5
possible fuel starvation? does it have a fuel filter? maybe it's shitted up?
Post by 90GTVert on Jan 12, 2012 17:57:46 GMT -5
Tried putting the stock airbox back on?
Post by teddy554 on Jan 12, 2012 19:00:24 GMT -5
i didnt check fuel filter will do that tomorrow, i Have tired stock air box but was worse then open filter
Post by 90GTVert on Jan 12, 2012 20:01:43 GMT -5
So does it improve with no filter? Are you using a larger main jet?
Post by teddy554 on Jan 14, 2012 11:02:28 GMT -5
no it didnt help and has far as i know it the stock jet at 70 main
Post by 90GTVert on Jan 14, 2012 13:01:02 GMT -5
I woulda thought the stock filter should help if it's a small main, but I'd still try a larger jet first.
Post by teddy554 on Jan 14, 2012 15:13:58 GMT -5
alright
Post by teddy554 on Jan 16, 2012 9:34:14 GMT -5
after knew spark plug and cleaning fuel lines and filter i put stock filter back on like 90gtvert said earlier in the post and adjusted mixier screw and now it run better and doesnt bog down at full throttle, really didnt get much time to really test it out last night so i will today. this zip does not have a kill switch and last night i unpluged all the alarm connections and after starting it it wouldnt shut off after turning key off i think my plug br7sha is that to hot of plug the plug in it br6h which i know is not right for it
Post by 90GTVert on Jan 16, 2012 9:42:28 GMT -5
Post by teddy554 on Jan 16, 2012 22:03:04 GMT -5
the wire jump work perfect for me thanks 90gtvert. this project involves one rx8 and one zip. i am taking parts of rx8 and putting them on zip to get one scooter running. i have to change the oil reservoir next because there is a big puddle of oil under scooter every day. today, strange enough no oil but gas. So that is next step in project rx zip
