palehorse
Off grid in Idaho
Post by palehorse on Jun 14, 2024 15:38:22 GMT -5
Here is the crank check video. I was working in low light with a headlamp so light is wonky but you can see it.
Post by aeroxbud on Jun 14, 2024 15:44:48 GMT -5
You will get massive vibration with that. It will kill the seals and bearings. Such a shame.
palehorse
Off grid in Idaho
Post by palehorse on Jun 14, 2024 15:52:55 GMT -5
OK, I think I am going to wrap a tie-down strap around the tip and point the high spot towards the front wheel and give it a tug towards the back wheel, see what happens. Its all chit at this point anyways... If I can get it straight Im going to ride it. There is a garaged stored vino with low miles here for 650 that is super clean. I am trying to contact them now but not replying.
You can ride quads and dirt bikes on the road here without any licenses. I have been keeping my eye open for a cr500 dirt bike. I'll put crossover tires on it and rip around. I can ride my quad to the grocery store but it wears the tires down and they cost $$$
palehorse
Off grid in Idaho
Post by palehorse on Jun 17, 2024 18:55:52 GMT -5
Post by aeroxbud on Jun 18, 2024 3:43:56 GMT -5
Not that I know of. Sorry.
palehorse
Off grid in Idaho
Post by palehorse on Jun 20, 2024 23:31:26 GMT -5
Well, since I have to put everything into it now. Can you recommend parts to use? Can I run a corsa cylinder, piston and head? Ive read that gives 12hp gain. If I am doing everything I want fast and more HP. But within reason. I dont want to spend 2k, closer to 1k or less if possible. No junk parts.
Post by aeroxbud on Jun 21, 2024 3:34:28 GMT -5
If you are considering the Polini corsa. I would also look at the stage 6 sport pro, or Malossi MHR replica cylinder. All similar performance. My favourite setup is the stage 6 street race paired with a Yasuni R. It would give you a substantial power increase. But he very tractable on the street.
Post by bigmatthew86 on Jun 21, 2024 6:00:51 GMT -5
I had that combo on a Zuma & it was a very good setup. Still very reliable but ran very strong.
palehorse
Off grid in Idaho
Post by palehorse on Jun 22, 2024 19:34:34 GMT -5
If you are considering the Polini corsa. I would also look at the stage 6 sport pro, or Malossi MHR replica cylinder. All similar performance. My favourite setup is the stage 6 street race paired with a Yasuni R. It would give you a substantial power increase. But he very tractable on the street. Ok I will do some research. I can only imagine how fast the vespa 350 GTS is. I bet it runs good. I didnt get that one that was up for sale for 1500. He had over a hundred buyers in line.
