Post by torinoman on Jul 18, 2024 7:35:06 GMT -5
Post by torinoman on Jul 18, 2024 11:06:56 GMT -5
I believe I can get my hands on an 08 Zuma pulley. That should have straight grooves, right? Any problems swapping those or is it a direct replacement?
Post by Zino on Jul 18, 2024 13:00:42 GMT -5
You need the whole rear 2008 pulley both sides that touch the belt It has straight grooves I used the 2008 pulley on my 2003 zuma
Post by torinoman on Jul 18, 2024 13:21:42 GMT -5
You need the whole rear 2008 pulley both sides that touch the belt It has straight grooves I used the 2008 pulley on my 2003 zuma Cool. I'll have both sides of the pulley. Did it give you decent results? I know there's something different between the prebug and your 03 in the torque driver. Exactly what, I'm not sure. Hopefully it will be a bolt on deal.
Post by torinoman on Jul 18, 2024 18:03:21 GMT -5
Ok. Just put on the 2008 Zuma pulley. Everything seemed to be a direct swap over. Much more linear rpm's. Overall pretty happy with it. Certainly the cheapest route to go! As always, thanks for the advice and tips!
Post by Zino on Jul 18, 2024 18:45:33 GMT -5
the 2008 Zuma pulley worked great for me .
