Post by ziptiejones on Aug 30, 2024 13:33:25 GMT -5
Pretty sure those are air screws. Turn it in for richer. General target is 1 1/2 turns out. Did you raise that needle? That’ll give you more fuel off the bottom and through the mid range but it’ll be same at WOT. I'll give that a try. Idk why I was thinking 2 1/2 out. 🤦♂️ I'm a mess right now lol
Post by broyager on Sept 3, 2024 3:44:23 GMT -5
Let everyone know;
What type of plug you're using Exactly what cylinder kit is installed What brand and model the carburetor is (even if it's stock) and the main and idle jet that are currently installed What state the airbox or intake is in / installed.
There will be a rough baseline of what should work, and if that's met then it might be something odd like, exhaust leak, dirty carb, air leak on the intake side etc
