Post by Deleted on Apr 4, 2012 22:44:12 GMT -5
its still there.
Post by bucket6429 on Apr 5, 2012 20:25:46 GMT -5
yea
Post by bucket6429 on Apr 8, 2012 9:25:36 GMT -5
how do i stretch my gy6 50 but not do the 150 swap :bfg:
Post by rocketdog on Apr 8, 2012 11:28:04 GMT -5
how do i stretch my gy6 50 but not do the 150 swap Make an extended motor mount is one way. Like this. Here's a 50 with a 6inch extension.
Post by Deleted on Apr 8, 2012 14:05:06 GMT -5
get a long case 788 motor for it.....and a 12" wheel.
this will give it the extended look...but use the standard motor mount.
Post by rocketdog on Apr 8, 2012 18:55:09 GMT -5
Kinda pricey that way, but it will work.
Post by Deleted on Apr 8, 2012 19:17:23 GMT -5
good point i paid $220 for the 788 motor and i think 60 for the wheel...and its still a 39mm bore. an extended mount would be much cheaper.
Post by bucket6429 on Apr 8, 2012 20:03:40 GMT -5
i had the dea of making an extended mount like a 9-11 inch stretch but can i use my stock shock
Post by rocketdog on Apr 9, 2012 6:37:02 GMT -5
i had the dea of making an extended mount like a 9-11 inch stretch but can i use my stock shock Yes you could but not the stock mounts. See where the shock attaches to the engine? It's inclined forward so far it's about to hit and much more of an angle would render it useless. Mines iffy. Easiest way would be to move the upper mount rearward in order to alleviate the problem. Another thing is that extending it a lot more than 6 inches might require a different design. My opinion is that 11 inches longer than the normal length might not be very strong or safe. Your going to be putting a lot of stress on that front pivot bolt. I think if it were me I would use some kind of weld on A frame extension or an entire custom frame. 6 inches seem to work out ok. Here's what it looks like before I deleted the rear body panels.
Post by bucket6429 on Apr 10, 2012 20:57:08 GMT -5
the 6 is what ill do and so with a 6 inch stretch could i use the stock shock and could u make me a mount and let me buy it :drool:
Post by 90GTVert on Apr 11, 2012 8:45:24 GMT -5
