come june lky2 (Motor spec added) May 8, 2012 6:52:31 GMT -5 Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by Deleted on May 8, 2012 6:52:31 GMT -5 where can a larger than 63mm bore be found?
come june lky2 (Motor spec added) May 8, 2012 7:47:21 GMT -5 Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by ravensguildassasin on May 8, 2012 7:47:21 GMT -5 here is a 67mm bore. www.drowsports.com/product/614/Engine/Cylinder_Kit/Taida_GY6_150cc_67mm_Ceramic_Big_Bore_Cylinder_Kitand here is a 65mm bore. www.drowsports.com/product/611/Engine/Cylinder_Kit/Taida_GY6_65mm_Big_Bore_Cylinder_Kitalso here is a +8.2mm stroker crank. www.drowsports.com/product/639/Engine/Crankshaft_Kit/Taida_GY6_8200_Stroker_Crankshaft__8_2mmit makes it possible to make a 232cc gy6 the best parts is the 67mm bore jug is made to accommodate the stroker crank so no spacing is needed.
