Post by maconboi on Apr 29, 2012 11:36:05 GMT -5
oh yeah and another thing i want to do a compression test. i have a tester but the hose is to big for the tiny threads of the plug on the scoot. Do they sell and adapter to fit it? i work in auto parts but don't recall we sell one. might have to go to a small engine supply or somewhere online. what's a normal factory stock PSI on these 63cc's?
Post by Deleted on Apr 29, 2012 11:50:16 GMT -5
ALL taotao scooters like in your avatar= 44mm bore 63cc.
10mm adapter for the compression gauge
you want somewhere in the 170psi area
Post by Deleted on Apr 29, 2012 11:54:02 GMT -5
Post by maconboi on Apr 29, 2012 12:00:27 GMT -5
that's awesome thanks for the info i'll go in and check when i get the plug see if we have a 10mm adapter. i'll keep you guys posted.
Post by maconboi on Apr 29, 2012 14:57:19 GMT -5
Alright i changed my plug i'm going to watch that and see. i opened both carbs the keihin cvk, and the factory sealed carb. (destroyed the bowl plate in the process) what i found was quite the opposite. in the fact how the jets were numbered in the factory carb the jets were 78 main and 30 idle. also i'm including a pic of the plug i took out. guess i can only load one pic at a time... Attachments:
Post by maconboi on Apr 29, 2012 15:02:23 GMT -5
keihin idle jet Attachments:
Post by maconboi on Apr 29, 2012 15:04:03 GMT -5
main jet side Attachments:
Post by maconboi on Apr 29, 2012 15:04:31 GMT -5
main jet top Attachments:
Post by maconboi on Apr 29, 2012 15:05:40 GMT -5
jets in carb Attachments:
Post by maconboi on Apr 29, 2012 15:10:31 GMT -5
factory sealed carb inside sorry had better pic but was to large Attachments:
Post by maconboi on Apr 29, 2012 15:12:36 GMT -5
main 78 jet factory carb Attachments:
Post by maconboi on Apr 29, 2012 15:13:57 GMT -5
idle jet factory carb Attachments:
Post by maconboi on Apr 29, 2012 15:17:29 GMT -5
oh and the keihin cvk jets as you can hopefully see are unmarked...
Post by Deleted on Apr 29, 2012 16:43:33 GMT -5
oh and the keihin cvk jets as you can hopefully see are unmarked... post the link where you got the Keihin carb.
Post by Deleted on Apr 29, 2012 16:44:46 GMT -5
only the top part of that is the main jet not the whole thing.
