Post by canemanscooten on Jun 5, 2012 17:52:25 GMT -5
Ok so here are my engine specs off the metal plate near my engine:
ENGINE DISPLACEMENT: 49cc ENGINE FAMILY: 9YYGC.049BZU PERMEATION FAMILY: 9YYGPMETALB1
ENGINE TUNE UP SPECIFICATIONS: IGNITION TIMING: 13º±1.5ºbtdc IDLE SPEED: 1500rpm ± 100rpm IDLE MIXTURE: NON ADJUSTABLE <-- Is this a problem?? VALVE CLEARANCE: 0.08mm SPARK PLUG:NGK/C7HSA SPARK PLUG GAP: 0.6-0.7mm
MANUFACTURED BY BENZHOU VEHICLE INDUSTRY GROUP
Do you guys know much about these engines? are they pretty common? what are some cons to this engine? Thanks
Post by Deleted on Jun 6, 2012 20:49:14 GMT -5
its a 139qmb just like all the others.
if it has a sealed carb replace it with a good one asap. sealed carbs run lean and hot which burns the rings up.
cons? little power but thats to be expected from a true 49cc engine.
Not all '50cc' chinese scooters are really 50cc though. some are 63cc and a very few are 72cc. The secret 72cc days have all but come to an end really. I have a few left.
Post by canemanscooten on Jun 6, 2012 22:52:32 GMT -5
i tried to talk to wife into letting me buy one of the 'secret 72's 'but we are getting ready for a child and didnt wanna spend the money right now...
how would i go about finding a replacement carb and how would i go about doing it?
Post by Deleted on Jun 6, 2012 23:29:55 GMT -5
1. take seat bucket off 2. unplug choke 3. some carbs have the style of drain hose that is secured down on one of the cvt cover bolts. remove screw to unsecure it. 4. unhook throttle cable 5. unhook intake hose from airbox at the carb 6. loosen the clamp on the intake manifold and remove carb. 7. unhook gas line from the carb 8. drain the bowl into your gas tank
reverse procedure to install. after installing take the vacuum line off the intake manifold and suck on it to open the fuel petcock to fill the bowl with gas.
Post by canemanscooten on Jun 6, 2012 23:37:55 GMT -5
awesome thanks... sounds like a plan i may have to look into quickly
