Post by torinrage on Jun 29, 2012 22:09:31 GMT -5
So i measured the variator today and i have a 86mm one. Now i am going to order a 96mm Hoca i think it'll fix it maybe. I'll post it again after i install it.
Also what head would you recommend for a 1p39qmb that works.
Post by ososlow on Jun 30, 2012 7:14:21 GMT -5
there isnt one? why would you spend money on a head when all you need is the rocker asym.
Post by torinrage on Jun 30, 2012 16:40:02 GMT -5
Post by torinrage on Jul 1, 2012 22:47:19 GMT -5
it has now been confirmed....i have built a turd....so its time for a redo *sigh*
Post by 90GTVert on Jul 2, 2012 8:17:02 GMT -5
There are some GY6 50s that have that style of 2T transmission, but most don't. If it's the 2T style you'd have an aluminum variator fan (fixed half) and a starter clutch behind the variator. If it's the normal GY6 CVT they usually have a steel fixed half with teeth on the outer edge and use a starter bendix that sits up above where the variator is. You can't swap parts between the two styles to my knowledge.
Post by torinrage on Jul 10, 2012 17:22:15 GMT -5
Well this week end coming up should lead to a whole new scooter just got my new hoca piston and rings from parts for scooter. ill update later when it is installed.
Post by torinrage on Jul 11, 2012 21:08:03 GMT -5
***UPDATE******
Ok installed new hoca piston and ring installed...pick up another 50mm jug around the the area the guy had gotten from scrappy dog.
Also fixed both the connectors in the coil was haven a spark isssues.
scooter now finally goes past 25mph which i rocked the gps on.... new i can hit around 33-34 mph... now will see what it does after i start fine tuning and breaks in.
