Post by thestratomaster on Aug 5, 2012 11:37:08 GMT -5
Looking for some help identifying what motor came in my Adly Silverfox I recently picked up. Grabbed it for $80 for a fun project and a future commuter to campus.
These are the only "engine codes" I've been able to find and unfortunately google hasn't come up with too many successful results.
On the side of the head: 3YJ0049 cm^3 On top of the cvt cover: JTJ077967 On the back of the cvt cover somewhat hidden by back wheel: HC1CJT On tag inside storage compartment: 7HRCC049STR (listed as engine family on the tag)
I was under the impression that it was a 4 stroke motor, but the tag in the storage compartment said to use 2 stroke oil only. Now I'm wondering why the previous owner left a receipt for 4 stroke oil in the storage compartment!!
Post by 90GTVert on Aug 5, 2012 11:49:21 GMT -5
From the pics I see of that model, it's a 2 stroke. Should be a minarelli / jog / 1e40qmb style of engine. I think all of the Adly engines vary from the most common of the Chinese 1E40QMBs. Usually we have a short or long case. You can see them both here... 49ccscoot.proboards.com/index.cgi?board=yamajog&action=display&thread=999They both use different final drive transmission setups. The long case normally has the gearbox extend past the CVT cover to make the extra length. I think the Adly uses a short case transmission with a stretched out CVT housing. The main reason I'm pointing this out is that you'll need a longer drive belt than the standard 1E40QMB uses. You'd need a different CVT cover too, but that's not something you will likely need to replace under normal circumstances. I'd drain whatever oil is in the reservoir and put in something that I know is 2T oil.
inuyasha
Retired Master Chief USN
Post by inuyasha on Aug 5, 2012 12:07:03 GMT -5
Post by thestratomaster on Aug 5, 2012 12:36:18 GMT -5
1e40qmb should be stamped on the case somewhere right? Where should I be looking for it? From the pics I see of that model, it's a 2 stroke. Should be a minarelli / jog / 1e40qmb style of engine. I think all of the Adly engines vary from the most common of the Chinese 1E40QMBs. Usually we have a short or long case. You can see them both here... 49ccscoot.proboards.com/index.cgi?board=yamajog&action=display&thread=999They both use different final drive transmission setups. The long case normally has the gearbox extend past the CVT cover to make the extra length. I think the Adly uses a short case transmission with a stretched out CVT housing. The main reason I'm pointing this out is that you'll need a longer drive belt than the standard 1E40QMB uses. You'd need a different CVT cover too, but that's not something you will likely need to replace under normal circumstances. I'd drain whatever oil is in the reservoir and put in something that I know is 2T oil.
inuyasha
Post by inuyasha on Aug 5, 2012 12:44:27 GMT -5
1e40qmb should be stamped on the case somewhere right? Where should I be looking for it? From the pics I see of that model, it's a 2 stroke. Should be a minarelli / jog / 1e40qmb style of engine. I think all of the Adly engines vary from the most common of the Chinese 1E40QMBs. Usually we have a short or long case. You can see them both here... 49ccscoot.proboards.com/index.cgi?board=yamajog&action=display&thread=999They both use different final drive transmission setups. The long case normally has the gearbox extend past the CVT cover to make the extra length. I think the Adly uses a short case transmission with a stretched out CVT housing. The main reason I'm pointing this out is that you'll need a longer drive belt than the standard 1E40QMB uses. You'd need a different CVT cover too, but that's not something you will likely need to replace under normal circumstances. I'd drain whatever oil is in the reservoir and put in something that I know is 2T oil. Hi i125.photobucket.com/albums/p48/dooley_09/craigslist%20pics/SUNDIRO%20%2050%20Minarelli/IMAG0007.jpgLook in that area Take care and ride safely Yours Hank
Post by 90GTVert on Aug 5, 2012 12:46:49 GMT -5
Some manufacturers use their own engine codes and never stamp them with the more common codes.
Post by thestratomaster on Aug 5, 2012 13:01:27 GMT -5
That's exactly where mine says this JTJ077967
Post by thestratomaster on Aug 5, 2012 13:02:10 GMT -5
Some manufacturers use their own engine codes and never stamp them with the more common codes. Is there anyway to confirm which of the more common codes mine is? I want to make sure I buy the right parts!
Post by 90GTVert on Aug 5, 2012 14:17:10 GMT -5
If it looks like what you're seeing in the diagrams in Hank's links, it's a minarelli/1e40qmb style. Other option would be to post a few views of the engine/cvt for us if you aren't sure.
Post by thestratomaster on Aug 5, 2012 14:47:11 GMT -5
If it looks like what you're seeing in the diagrams in Hank's links, it's a minarelli/1e40qmb style. Other option would be to post a few views of the engine/cvt for us if you aren't sure. I'll compare the diagrams and post a few pics later
Post by jmkjr72 on Aug 5, 2012 16:01:03 GMT -5
as far as i know most all the adly 50s are hm engines they are a hybrid so they wont have any of the comon markins on them they are long case engines with short case trans
Post by thestratomaster on Aug 7, 2012 18:32:08 GMT -5
Post by jmkjr72 on Aug 7, 2012 18:38:56 GMT -5
drain the oil tank if your worried but some people actauly run regular engine oil in the trans instead of gear oil
Post by thestratomaster on Aug 7, 2012 18:41:26 GMT -5
Unfortunately given the shape the scooter came in, I'm going to say that the owner was not keen enough to use it as gear oil hah
Post by thestratomaster on Aug 7, 2012 20:16:50 GMT -5
Does this look like a Minarelli to you guys?
