Post by 2strokd on Nov 14, 2012 9:44:38 GMT -5
I will just post the pic and ask why to start the thread... Why?
Post by teddy554 on Nov 14, 2012 15:07:37 GMT -5
guessing, over heated. but thats crazy
Post by 90GTVert on Nov 14, 2012 17:55:55 GMT -5
Looks like heat deformed it, but I dunno how it gets so hot at the intake. Backfire was a thought. I've had that bend back metal reed stops before.
Blowin Smoke
Post by Blowin Smoke on Nov 14, 2012 19:51:43 GMT -5
Probably happened when you shut it down.
Post by 2strokd on Nov 15, 2012 11:24:47 GMT -5
Dunno? All ive got to go on so far is the splash of race fuel that i put into the tank. It never got that hot to my knowledge?.. Didnt backfire.
These reeds are supposed to be ok in alcohol so i assumed a splash of race fuel would be fine too?
Post by lshigham on Nov 15, 2012 15:08:04 GMT -5
Does look like heat got to them, time for some CF ones!
Post by lshigham on Nov 15, 2012 15:18:47 GMT -5
I haven't had much luck with those reedblocks either... The rubber went saggy and fell off, no strange fuels or anything. Did make it run rather rough!
Aaron420e
2008 Keeway F-ACT Racing
Post by Aaron420e on Nov 15, 2012 21:00:13 GMT -5
:panic: I have that same reed block. Hope mine doesn't melt too.
Knock on wood... :beatup:
Post by stepthrutuner on Nov 15, 2012 21:49:18 GMT -5
The resin in those reeds obviously didn't like th' 'zotic drank u gave ol' skeedr.
Post by 2strokd on Nov 16, 2012 15:41:35 GMT -5
Post by 2strokd on Nov 16, 2012 15:42:51 GMT -5
I did replace the reeds with the other set that comes in the kit. Also put the stops back on the cage.
No problems yet....
Post by reveeen on Nov 16, 2012 18:48:33 GMT -5
Maybe they are making a cheaper version now?
Keeping FIRMLY in mind: Stage6 has no manufacturing facilities.... everything is batch manufactured in China, so the cheapest bidder gets the contract: quality control? What's that?
Post by stepthrutuner on Nov 16, 2012 18:55:04 GMT -5
Again Reg, this is not from Skeedr. Anyhow,That fuel was made by a chemist that makes fuel here I guess I missed something. What scooter is that reed set from?
Post by stepthrutuner on Nov 16, 2012 19:17:53 GMT -5
What is that bead of stuff near the perimeter of the reeds' sealing surface? Think that stuff could have expanded and caused the warpage?
Post by 2strokd on Nov 17, 2012 14:51:34 GMT -5
The minarelli reedblock pictured is from a Keeway F-act. Stage6 build i did for a guy. Its been fine since the reed petal replacement and the stops added. Maybe the messed up from not having the stops in?? Never happened to me before but who know, first time for everything huh?
Im not sure what the stuff is? Maybe it did it?
