Post by derbiman on Jan 7, 2013 18:00:46 GMT -5
Just picked up a Derbi Hunter Manhattan for cheap. Prior owner melted the piston on a Malossi 70cc kit.I ordered a new kit for it and am using the old Malossi head.It has a Dellorto 19 phbg but I think the previous owner did not up jet enough(76 main).Any suggestions on carb set ups? I am going to pre-mix the first tank of gas and put a small bottle on the end of the oil line to see if the pump is functioning properly.Also, the wrist pin bearing may have been compromised from the meltdown. Can anyone tell me where I can pick one up locally? It has the 10 mm wrist pin and the dimensions are 10x13x14mm. Thanks
Post by Corrosion on Jan 7, 2013 18:51:19 GMT -5
Post by derbiman on Jan 7, 2013 18:56:29 GMT -5
It has the Derbi ac motor.
Post by teddy554 on Jan 7, 2013 19:21:10 GMT -5
