toto50
Bring the Motherf***king Ruckus!
Post by toto50 on Apr 6, 2013 13:38:00 GMT -5
is this the only way to reduce the kickback? I'm also having starting issues with electric start i know i need a new battery but i think the starter is not strong enough to kick over the engine all the time. I want to upgrade all the battery cables and install a bigger battery. What battery would you guys suggest. Also i havnt installed the oil pump the kit came with should i change it out and there is a plastic sprocket that came with the kit where does this go. www.ebay.com/itm/150986329487?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Post by Deleted on Apr 7, 2013 21:00:27 GMT -5
no need to install the oil pump from the kit. you need to do a compression test, your kick back and hard starting issues are most likely very high compression. let us know what the reading is. do the test properly for correct reading. put some oil down the spark plug hole and hold the throttle wide open when spinning it over. lets see what the reading is before we start throwing more parts at it
toto50
Post by toto50 on Apr 8, 2013 15:09:41 GMT -5
I installed the 8grams rollers last night really didnt feel a difference but there in there now and since i had tranny apart i moved the kickstart to 1'o clock position. it so much easier to kick start now without the kick taking a beating. thanks @1fastqmb i will do a compression test asap. I know i do need a battery though and i might as well get a bigger one what do you recommend for a battery. I saw your thread about upgrading the cables and willing to do that if i have too. ohh i can do now
toto50
Post by toto50 on Apr 8, 2013 21:00:29 GMT -5
well i got a loaner compression tester but the attachment didnt fit need to find the correct size adapter.What should my compression be i have 50mm piston. Since i got the spark plug i wanted to compare it to the spark plug diagram but i cant find it. Can you point me in the right direction.
millsc
Post by millsc on Apr 9, 2013 8:00:00 GMT -5
I take my rubber mallet and bang one side of the rocker assembly, the side where the holes are and the other side will pop out, works every time
Post by Deleted on Apr 9, 2013 13:34:51 GMT -5
150 psi or better but not over 200 psi
toto50
Post by toto50 on Apr 9, 2013 13:46:23 GMT -5
thanks. now i need to try to locate a compression tester with the correct attachment size?
Post by Deleted on Apr 9, 2013 14:04:17 GMT -5
toto50
Post by toto50 on Apr 9, 2013 14:18:54 GMT -5
toto50
Post by toto50 on Apr 9, 2013 14:32:32 GMT -5
you think they sell that adapter at auto zone or advance?
Post by Deleted on Apr 9, 2013 17:15:37 GMT -5
I will go check i gotta go to autozone anyway and its just up the block. You got thaose 69mm rockers? I need em.
Post by Deleted on Apr 9, 2013 18:36:05 GMT -5
Autozone does not have just the 10mm adapter and the compression tester rental they have only has 14mm and 18mm. Seems like if was in a local parts house I would have gotten it I went through all this last year and ended up on ebay.
The $40 tester Autozone sells has 10,12,14 and 18mm
I use a $15 ebay gauge and that adapter above i posted the link to.
toto50
Post by toto50 on Apr 10, 2013 9:18:34 GMT -5
Since i wasnt able to get a compression tester I went ahead and disassembled and reassembled the motor and installed an extra base gasket and set the valves set at .004 intake, .005 exhaust this morning. I havnt tried to start it since i finished at 3am and didnt want to wake everyone up. Hopefully this lowers the compression to where the electric start can start the engine.
toto50
Post by toto50 on Apr 10, 2013 22:24:50 GMT -5
Well i try to start it with a new battery from a new taotao and still wasnt able to start it with the eletric start. the starter was turning but it just wasnt strong enough. what to do?
Post by Deleted on Apr 11, 2013 1:18:18 GMT -5
compression test
