Post by supermel74 on May 20, 2010 18:41:39 GMT -5
Mine has the long case Minarelli. Is there any difference besides the length?
Post by 2strokd on May 20, 2010 18:52:29 GMT -5
Nope, shouldnt be! Ide try a 780 or a 788
Post by supermel74 on May 20, 2010 19:42:07 GMT -5
I actually tried the 788 without making sure it was the right size first :doh: and it ended up being way too short(90mm I assume)
Post by 2strokd on May 20, 2010 20:04:10 GMT -5
I actually tried the 788 without making sure it was the right size first and it ended up being way too short(90mm I assume) You have one i havent seen yet :stumped:
Post by andsetinn on Jun 21, 2010 13:57:25 GMT -5
I'm wondering if one of the belts is for restriction purposes? Or for different variator/clutch setup? Thinner belt goes further into the variator/clutch on one end but on the other end it wont go as far out because the faces don't go close enough together? I would've thought that the thinner belt would also need to be shorter.
