Post by 70ccsuperyates on Oct 7, 2013 20:52:05 GMT -5
They have 2 headlights but one is low and one is high. We rewire them so we have 2 low and 2 high. Looks better and gives us better night vision. Sent from my SPH-L720 using proboards very nice I like the idea bet it sure lights up the night huh
Post by ryan on Oct 7, 2013 22:08:16 GMT -5
i did the same thing on the zuma i had here
Post by moofus02 on Oct 8, 2013 3:05:40 GMT -5
It really lights up the night
Post by jmkjr72 on Oct 8, 2013 17:57:23 GMT -5
The efi lcz has had a vino wire harnes grafted into it and a im looking for a small spline stroker crank for my 54 mm bore kit on the adly 90 case with 8.86 to 1 gear ratio
Work has realy sucked sand being the lcz is my high dollar project it has been on hold
I start a new job next week so hope to have money to work on it this winter
Post by moofus02 on Oct 8, 2013 18:55:45 GMT -5
The efi lcz has had a vino wire harnes grafted into it and a im looking for a small spline stroker crank for my 54 mm bore kit on the adly 90 case with 8.86 to 1 gear ratio Work has realy sucked sand being the lcz is my high dollar project it has been on hold I start a new job next week so hope to have money to work on it this winter I picked up a vino stator and Flywheel also no wire harness yet. My 103 Zuma is small spline Small taper 45 stroke. I've got a 45 stroke large spline small taper crank for the adly cases I'm going to use in my Eton. The Eton is dc already and has to electric start for the wife so I think the Eton gets the cool 12 pole stator. Would it be easier to change the center of the Flywheel for a large taper one instead of changing cranks? I thought about that but it fits 2 out of 3 of my cranks. I don't have the 103 in yet but it's got 9.25 gears but I have a 8.4 option as well. The adly cases are about 10:1. How do you like that 8.8 gear? Could you use more or less? Sent from my SPH-L720 using proboards
Post by PIG on Oct 8, 2013 20:29:21 GMT -5
I built these pegs for about 30 bucks. One of the best mods I've done. Lots of leg room now.
Post by 70ccsuperyates on Oct 8, 2013 20:51:41 GMT -5
Well in the even it sees the pavement they will save your plastics along with the handlebars
Post by jmkjr72 on Oct 9, 2013 19:52:33 GMT -5
Atv gears The issues with the flywheel the number of magnets The stator with more poles needs a flywheel with more magnets
I need a crank that will handle 10 grand plus
Post by ryan on Oct 9, 2013 20:17:41 GMT -5
go to treatland pick up a doppler crank jmkjr
Post by ryan on Oct 9, 2013 20:22:28 GMT -5
oh sorry i ddnt see the 45mm stroker. there is one forsale at autotech
Post by kevin55950 on Oct 10, 2013 15:48:59 GMT -5
MVT are 44.8, Kiesler are pretty cheap and 44mm, Airsal (but the rod is pretty short, 45mm stroke), MXS Racing are 45mm stroke, unless you'd like to go with malossi, stage6 or bidalot, these are the least expensive choices if you want to go 10K rpm+.
Post by jmkjr72 on Jul 16, 2014 21:46:56 GMT -5
today I did just slap on the leo sp3 I got Didn't do any tuning at all and boy it sucks out of the hole but when you hit 25 to 30 it hits the pipe and takes off
What's my next plan I was going through my boxes of parts new and used as I thought I had a clutch with springs in it already but I must have used it else where But I did have another 08 torque driver and stage 6 clutch with white springs a stage 6 med contract and stage 6 433 bell So I'm going to give that a shot later got a get a battery or corded impact
Post by jmkjr72 on Jul 20, 2014 12:04:09 GMT -5
Got the impact stage 6 clutch is in white springs adjusted all the way out Got a mix of rollers in and now I gota order some 5.5 gram rollers
