Post by spaz12 on Jan 22, 2016 15:18:06 GMT -5
The pumps are really nice to have, but they have their limits. I think you're at it and you know that feeling when something f's up and you ask yourself why you didn't listen to your first instinct? As the owner of the twin towers said about building 7..."I think we should pull it."
Post by sublunacy on Jan 22, 2016 15:23:31 GMT -5
your crank and engine and exhaust so far is going to make 2 ft/lbs of torque till 9000rpm. better get the autolube deleted. if there is anyway i can help let me know.
Post by spaz12 on Jan 22, 2016 15:28:05 GMT -5
Seems to me if it's only going to make 2 ft lbs of torque then you might as well keep it.
Post by PIG on Jan 22, 2016 19:27:53 GMT -5
It's got it's new heart, just waiting for its new lungs to get here. I'm thinking the knobby tires gotta go as well. I'm thinking some boppers will get the nod. This should be a pretty quick scoot once it's all tuned in.
Post by spaz12 on Jan 22, 2016 19:43:40 GMT -5
Man, that thing is gonna be crazy on that little tiny prebug.
Post by PIG on Jan 22, 2016 19:46:20 GMT -5
Lmao. Good thing I posted these pics. I have the head on the wrong way! Tough to cool it that way.
Post by spaz12 on Jan 22, 2016 19:50:56 GMT -5
Oh damn! We had another guy do that and it didn't work out so well. Good catch!
Post by ryan_ott on Jan 22, 2016 21:05:14 GMT -5
Looking great. Makes me want one!
Post by PIG on Jan 24, 2016 16:37:13 GMT -5
I need some gauges for this thing. I can go without an rpm gauge, but I'd really like to have a temp gauge. Anyone know of a CHEAP but good temp gauge? Links would be great.
Thanks.
Post by triesandluth on Jan 24, 2016 17:10:16 GMT -5
Post by sublunacy on Jan 24, 2016 19:30:57 GMT -5
I need some gauges for this thing. I can go without an rpm gauge, but I'd really like to have a temp gauge. Anyone know of a CHEAP but good temp gauge? Links would be great. Thanks. - i like the tto water temp guage plus the wie extension. i have the m6 sensor- threaded into my aircooled head about 2 or 3 fins in. i have discovered that 170f is maybe a little cool. 185-195f is about right. 220 f is a little lean. 300-50 kills spark plugs. soft seizes. stops running etc. ----------
Post by ryan_ott on Jan 24, 2016 20:03:21 GMT -5
I use the TTO with the spark plug ring. It's accurate. Just use the ring on a air cooled motor or threaded insert on l/c. You will need an extention.
Post by PIG on Jan 24, 2016 20:04:02 GMT -5
I need some gauges for this thing. I can go without an rpm gauge, but I'd really like to have a temp gauge. Anyone know of a CHEAP but good temp gauge? Links would be great. Thanks. - i like the tto water temp guage plus the wie extension. i have the m6 sensor- threaded into my aircooled head about 2 or 3 fins in. i have discovered that 170f is maybe a little cool. 185-195f is about right. 220 f is a little lean. 300-50 kills spark plugs. soft seizes. stops running etc. ---------- 170? That's crazy low, I'd be checking your gauge. 300-350 is where I've alway ran my a/c stuff. 300ish 80% of the time with normal riding and long WOT up hills I'll see 350. In fact, I've never heard of one running that cold.
Post by ryan_ott on Jan 24, 2016 20:06:15 GMT -5
That's fin temp not plug temp.
Post by PIG on Jan 24, 2016 20:12:47 GMT -5
I've used those before and they work great. Thought maybe there was something different out there.
