Post by Sitticuss on Feb 19, 2014 4:45:22 GMT -5
I went to check the plug and the inside of the spark plug boot fell apart when I pulled it off. So I did a little creative repair with parts from and old coil that had failed.
Post by Sitticuss on Feb 20, 2014 0:20:11 GMT -5
Went out to the scooter today and was greeted by a puddle of oil. Leaking again from the top hose connection on the injector. There is just no clearance between the engine casing and the injector during part of pushing it back in it must be dislodging the hose just a bit when its reinstalled. So now i have to pull the jug again and disconnect the pipe etc etc. Just don't have the patience now to deal with it. Stuck a bucket under it and walked away. I need to do just a little grinding with the dremel so the top hose connection doesn't get pushed around when installing it. As my dad used to say "I hope whoever designed this designed one more and died"
Post by Sitticuss on Feb 20, 2014 0:33:07 GMT -5
I also ordered a new 54mm top end, some new rear brake shoes, and a shorter rear brake cable. I'm sure the wife won't mind at all...but i did have a credit and a coupon.
Post by 90GTVert on Feb 20, 2014 8:55:42 GMT -5
Switching to pre-mix would fix that leak for sure.
Post by Sitticuss on Feb 20, 2014 10:30:00 GMT -5
Switching to pre-mix would fix that leak for sure. Yeah, but I would still need to fix the leak first. Twisted I know but that's how I roll....
Post by Sitticuss on Feb 20, 2014 13:21:47 GMT -5
50cc I don't think so buddy. My partner and I are experts on size. You won't be "getting off" with a warning. We are going to have to make things "harder" for you this time....
Post by Sitticuss on Feb 20, 2014 14:52:56 GMT -5
I pulled out the injector and discovered the outside top edge of the nipple was sharp. Since its such a tight fit putting the injector back in the hose gets compressed against it and it actually cuts the hose. Sanded it down with 220 grit sandpaper put the hose back on and pushed the injector past the hard area. Didn't put it all back together just going to wait and see if it leaks again. I also twisted the crap out of my ankle in martial arts class, so I got a pass on chores and going shopping with the wife...
Post by Sitticuss on Feb 21, 2014 2:42:09 GMT -5
Good news the injector isn't leaking anymore... Bad news my ankle is to swollen and sore to ride it now. And my last ride was so much fun!!! The universe hates me
Post by Sitticuss on Feb 21, 2014 3:23:52 GMT -5
I need a center stand to fit the bottom of the polaris engine. I'm assuming thats what the bracket is for.. Which would be nice because I cut the old one off the frame do to the fact it was impossible to try and get a pipe mounted. Any suggestions would be great.
Post by 90GTVert on Feb 21, 2014 5:56:51 GMT -5
Post by Sitticuss on Feb 21, 2014 6:07:30 GMT -5
Cool thanks...ordered it
Secret 90
Feb 21, 2014 7:12:39 GMT -5
via mobile
Post by 2TDave on Feb 21, 2014 7:12:39 GMT -5
I had to remove my center stand in order for my pipe to fit. Is there something else I could use?
Post by 90GTVert on Feb 21, 2014 9:33:47 GMT -5
I know there are short and long case centerstands, or maybe it's 10" wheel and 12" wheel stands. One is definitely shorter than the other at any rate. Not sure if there are other variations. I'd guess yes, but no experience with them. Not sure if any would help the issue. There's always the side/kick stand.
Post by Sitticuss on Feb 21, 2014 14:08:51 GMT -5
Partsforchinesescooters sent me and email telling me that that part it's available and will refund my money. but now that I know what so look for I'll just order it somewhere else.
Post by 90GTVert on Feb 21, 2014 14:26:45 GMT -5
