Post by Sitticuss on Feb 12, 2014 15:39:55 GMT -5
Going to take my motor down to a shop I've delt with a few times tomorrow and see what he has to say about it. I'd like to keep the gears the way they are because i'd rather have more of a top end even more since i am going down to a 10" wheel. I'm wondering if the shaft is different because it had a sprocket on it and not wheel. I just don't have enough experience in this area to know.
Post by 190mech on Feb 12, 2014 16:06:56 GMT -5
Ive got a China short case in the works now and checked the spline fit on a 12" CPI wheel,it slid in perfect.The short case spline appears to be formed and the long case CPI splines are machined.That makes them look different but both do the job..
Post by Sitticuss on Feb 13, 2014 16:29:06 GMT -5
Success 40 bucks with the tire and rim....
Post by 2TDave on Feb 13, 2014 16:32:33 GMT -5
Great deal!
Post by nelson on Feb 13, 2014 17:21:23 GMT -5
heck yea, you are in buisness man! So you used the scooter gears but had to buy a new rim? Did you have to change any bearings?
Post by Sitticuss on Feb 13, 2014 17:28:27 GMT -5
No all the bearings are in good shape. All the parts are still the ones i got with the motor. Yeah just the rim and tire.
Post by nelson on Feb 13, 2014 17:33:26 GMT -5
did you get the new bushing/bearings to mount the engine yet? if so from where?
Post by Sitticuss on Feb 13, 2014 18:04:10 GMT -5
I just needed two 6003-2rs bearings which i got from ebay
Secret 90
Feb 13, 2014 18:44:04 GMT -5
via mobile
Post by nelson on Feb 13, 2014 18:44:04 GMT -5
cool thanks for the info
Post by 190mech on Feb 13, 2014 19:53:21 GMT -5
What was that rear wheel off of??I'll need one soon!
Post by Sitticuss on Feb 13, 2014 20:03:44 GMT -5
No idea it was just something he had lying around the shop.
Post by Deleted on Feb 13, 2014 20:19:37 GMT -5
I haven't been reading this thread, but I have similar rear wheels in my gy6 139QMA/B engines (10").
Post by Sitticuss on Feb 15, 2014 3:05:41 GMT -5
Tearing apart the scooter now. here are a couple pics of the pipes i used and will be using. the top one is a 100 dollar pipe from ebay i believe its the same one scrappydog sells supposed to be able to use it with a 50cc to 90cc. Worked great on my 50cc but with my big bore kit there were exhaust flow issues. Got the other pipe from shakerdriver there is clearly a big difference here. Oh and thanks for the link to the flywheel puller i did order it.
Post by 2strokd on Feb 15, 2014 15:13:49 GMT -5
What was that rear wheel off of??I'll need one soon! I got you covered on that John
Post by 2strokd on Feb 15, 2014 15:16:13 GMT -5
Going to take my motor down to a shop I've delt with a few times tomorrow and see what he has to say about it. I'd like to keep the gears the way they are because i'd rather have more of a top end even more since i am going down to a 10" wheel. I'm wondering if the shaft is different because it had a sprocket on it and not wheel. I just don't have enough experience in this area to know. All you needed to do was take the sprocket off and wheel would have slid on...Or am i mistaken, did you get the wheel/tire itself+installed for $40? If so, thats not bad at all!
