Post by 90GTVert on Jun 22, 2014 9:30:41 GMT -5
You'll prob want to measure the conrod small end and check it vs a service manual spec. Look and feel for irregularities in the small end bore.
Post by Lucass2T on Jun 22, 2014 10:16:56 GMT -5
You'll prob want to measure the conrod small end and check it vs a service manual spec. Look and feel for irregularities in the small end bore. Do you think i can use the manual from a old, mid 90's Jog? And are there ways or specs on how to measure the small-end for wear or this kinda damage?
Post by 90GTVert on Jun 22, 2014 11:03:40 GMT -5
Any of the specs in a Yamaha Minarelli manual like the Jog or BWS or Zuma should be good I'd think... if you can find them. Maybe I'm just overlooking them, but this is about all I found in what I have from Yamaha. I know I've seen specs for the 12mm pin conrods in Chinese manuals.
Post by Lucass2T on Aug 26, 2014 16:04:17 GMT -5
So, after a long time there's a new update. Bought a new 12pin 'TRD' (twins racing division) crank. It's custom build in italy with the crankwebs from a Malossi RHQ and the conrod from a Polini Evo crank. The big-end bearing is a so called 'silver caged' bearing...at least thats how they call it in Holland. Also bought a new cylinder, again the Metrakit SP3 70. And AGAIN bought it on discount! It was the last item they had, lucky me! They where willing to switch the pin10 piston for a pin12 piston for free, without any hassle... GOOD JOB EUROSCOOTERS! I also did some work on the cylinder. Dunno if it will do any good, but it's more for my own peace of mind. Well, pics:
Post by 2strokd on Aug 27, 2014 8:57:38 GMT -5
Very nice! I had a SP series 47mm LC Mina cylinder i got on a crazy deal but i never used it on anything. Ended up selling and regret it now
Post by Lucass2T on Aug 29, 2014 16:57:03 GMT -5
Very nice! I had a SP series 47mm LC Mina cylinder i got on a crazy deal but i never used it on anything. Ended up selling and regret it now Was it the SP3 like mine? Or the SP2, the downgraded pro-race with the triple exhaust ports?
Post by 2strokd on Sept 2, 2014 2:23:57 GMT -5
im sure it was the older one? I couldnt complain at the time for $49USD Here are a few pics of it.
Post by Lucass2T on Sept 2, 2014 12:36:00 GMT -5
Yes! Thats the downgraded Pro-Race! $49USD is ridiculous haha! But nice, only heard stories about em.
Post by Lucass2T on Sept 23, 2014 13:31:59 GMT -5
Bought a new shock last week I was looking for something semi-high quality but not as craazy priced like the malossi RS suspensions. The option to adjust the damping could be a nice option. It had to be somewhere between 240 and 260mm's long and my budget was about €100. Searched and searched and searched and then came across this: So...now i'm wondering...if you look at the shock. You can see the adjusting knob is at the top secton of the shock while the gas reservoir and damper itself is in the lower secton. This would mean the rod is hollow in order the be able to adjust the damping, right? I guess my tecnical knowhow about shocks is reaching until there...can someone explain?
Post by 2strokd on Oct 13, 2014 11:56:12 GMT -5
Have you tried the shock yet? I am looking for a good replacement and am not having much luck
Post by moofus02 on Oct 13, 2014 12:00:14 GMT -5
Yes how do you like it?
Post by Lucass2T on Oct 13, 2014 14:23:45 GMT -5
Well, how do i like it... It's a true sport/racing shock. Very short travel, about 2 inches or so. And it's really stiff. So for comfortable cruising it isn't the best choice.
I set the spring preload on the weakest position becouse im only 140 pounds or so. The shock sets nicely to about 3/4 inch when i sit on the scoot. So the spring itself isn't too strong i think.
Would i buy it again? Yes, becouse it was really cheap compared to other adustable shocks. Unfortunatly Sebac (or the brand name) doesn't excist anymore. So you won't find too many anymore.
Post by Lucass2T on Nov 18, 2014 10:17:30 GMT -5
I'm really bored right now so im gonna post a semi useful update. Actually i should be working on my thesis project since im graduating in a month from my bachelor in applied sciences. Anyway... Last couple of wheeks been trenching the cases...this is what they look so far. Not finished yet, so they look a bit rough. I'll post again some pics when they're done. Also bought a 12'' 1.85 wide pitbike wheel for the diskbrake upgrade im gonna do, no pics of that. And this week bought an athena CDI with variable advance. Don't get that advance curve though... Shouldnt it start off way advanced and when the revs go up the advance gets less until powerband peak and then advances again? When i compare the HPI innerroter and the Top Performances cdi's with both variable advance curves none of them look alike. HPI CDI Top performances CDI Maybe someone can explain? I like the HPI curve the most becouse it starts off with most advance and then gently drops off.
Post by Lucass2T on Jan 17, 2015 10:33:10 GMT -5
Thus far nothing really happened here. Bought some parts like a 1.60 inch wide 12 inch pitbike front wheel, Yamaha Neo's front disk brake lever and caliper, Doppler steel brake lines. Worked on the cases a bit. Got a Dremel for my birthday so now i have my own! But progress is slow. I'm so busy with my school thesis im working non stop for the last couple of months. Slowly sourcing parts and stuff so when i'm done with school i can build up this thing right away!
Post by Lucass2T on Feb 5, 2015 15:36:25 GMT -5
Aight. I have set myself a new goal for the summer. Participate in a special scooter roadtrip from Amsterdam to Dyon (France). It's a 900 mile trip (450mi to 450mi from) and i'm gonna do it on the 70mph Axis! www.google.nl/maps/dir/Amsterdam/Dijon,+Frankrijk/@49.8420458,4.5013103,6z/am=t/data=!4m14!4m13!1m5!1m1!1s0x47c63fb5949a7755:0x6600fd4cb7c0af8d!2m2!1d4.8951679!2d52.3702157!1m5!1m1!1s0x47f29d8ceffd9675:0x409ce34b31458d0!2m2!1d5.04148!2d47.322047!3e1 The idea is just ride on your cheap ugly beater all the way to France and do some stupid assigments on the way. Like a cannonball run kinda thing. www.facebook.com/BourgondischeBarrelsYou guys prob don't understand a thing that's written there but if you look at the pics you'll get an idea. Man, this seems the coolest thing to do! Now i need to make sure the axis is done before june 22th.
