Post by pinkscoot on Jan 18, 2021 18:29:49 GMT -5
I have been thinking that the rat ET2 needs to be pink and white so that it will be a real sleeper.
Post by sevenninesandtens on Jan 19, 2021 9:22:52 GMT -5
I get those same looks on my pink Vino... but probably more confused than hot stud looks. Being I'm covered in tattoos and have quite a beard. I probably look like I escaped a mental hospital!
Post by FrankenMech on Jan 19, 2021 10:05:52 GMT -5
I get those same looks on my pink Vino... but probably more confused than hot stud looks. Being I'm covered in tattoos and have quite a beard. I probably look like I escaped a mental hospital! You did!
Post by jloi on Jan 19, 2021 12:50:08 GMT -5
Post by milly on Jan 22, 2021 7:08:08 GMT -5
Today I went for an MOT now things are getting stable with my mum. Very icey on the way this morning after all that rain and now a heavy frost 28f. I then treated myself to a faggot on the way back then a coffee. Next job is to strip and find what needs replacing as jumps out of third gear.
Post by pinkscoot on Jan 22, 2021 10:12:31 GMT -5
To translate Milley's post for those of you that don't speak his language here is a definition from Wikipedia "The word faggot in the UK also refers to a kind of meatball, while fag is most commonly used as a slang term for "cigarette"."
Or I could be wrong and we are learning more about Milly every day.
Edit: as I look back on the pictures what I mistook for a muffin looks a good bit like a giant meatball.
Post by aeroxbud on Jan 22, 2021 10:15:41 GMT -5
Knowing Milly, he probably had a fag with his faggot!
Post by milly on Jan 22, 2021 11:32:15 GMT -5
Nope I is not a iron hoof. and I had a fag with my coffee 😋
Post by pinkscoot on Jan 23, 2021 10:05:25 GMT -5
Milly you are teaching us all new slang.
Post by FrankenMech on Jan 23, 2021 12:10:30 GMT -5
Nah, it's just Welsh.
If I ever move to Scotland or Ireland, then after a few years we could sit and talk to each other for hours and never understand a single word. We both be deef or daft by then anyway.
Post by milly on Jan 26, 2021 14:20:02 GMT -5
Today I washed Violet get the road salt off. Then went to do indicator but it cut out and would not start. WD40 came to the rescue, took off side panel and a wire had come adrift on indicator easy fix for a change. I then got tin of spray paint for new sidepanel on cut down and will get on with that once finished friends electric bike.
Post by jbjhillbilly on Jan 27, 2021 11:33:18 GMT -5
...just need to top off the brake fluid and I can button this up... Customer “There’s something wrong with the front brake.”
Post by milly on Jan 27, 2021 11:50:03 GMT -5
...just need to top off the brake fluid and I can button this up... Customer “There’s something wrong with the front brake.” Nothing a bit of soapy water won't cure 😃
Post by aeroxbud on Jan 27, 2021 11:52:22 GMT -5
That's the worse one I've seen. And I've seen some bad ones. 😯
Post by FrankenMech on Jan 27, 2021 11:57:41 GMT -5
What causes the brake fluid to gel like that?
