Post by milly on Jan 18, 2023 18:38:59 GMT -5
sinfull
Post by sinfull on Jan 19, 2023 18:04:55 GMT -5
Worked on the bike again today, pretty close to getting it to start, I think my wiring is good, just need to figure out how to wire in a kill switch and start button
sinfull
Post by sinfull on Jan 19, 2023 18:07:59 GMT -5
Have a start button but nothing else, so I need to figure out how to bypass it and get it to button start. And then I can check for spark and what ever else
Post by mrchilled85 on Jan 22, 2023 12:05:49 GMT -5
got out to work on the malaguti-madison 125 tho was a bit hard having to use crutches
changed the carburetor to a naraku 30mm and got it running best with a 107 main jet and 35 pilot jet , new malossi multivar variator kit and belt
gear oil change and engine oil done as well new lockset fitted just waiting on frontpanel now then bike will be ready for mot after i have sorted out the brakes as they are not working due to cracked brake pipes leaking
but did not get them sorted today as leg started hurting to much
aitch
Post by aitch on Jan 22, 2023 13:55:05 GMT -5
got out to work on the malaguti-madison 125 tho was a bit hard having to use crutches changed the carburetor to a naraku 30mm and got it running best with a 107 main jet and 35 pilot jet , new malossi multivar variator kit and belt gear oil change and engine oil done as well new lockset fitted just waiting on frontpanel now then bike will be ready for mot after i have sorted out the brakes as they are not working due to cracked brake pipes leaking but did not get them sorted today as leg started hurting to much Brakes are overrated…
Post by mrchilled85 on Jan 22, 2023 14:03:21 GMT -5
got out to work on the malaguti-madison 125 tho was a bit hard having to use crutches changed the carburetor to a naraku 30mm and got it running best with a 107 main jet and 35 pilot jet , new malossi multivar variator kit and belt gear oil change and engine oil done as well new lockset fitted just waiting on frontpanel now then bike will be ready for mot after i have sorted out the brakes as they are not working due to cracked brake pipes leaking but did not get them sorted today as leg started hurting to much Brakes are overrated… so true
Post by aeroxbud on Jan 22, 2023 14:09:25 GMT -5
got out to work on the malaguti-madison 125 tho was a bit hard having to use crutches changed the carburetor to a naraku 30mm and got it running best with a 107 main jet and 35 pilot jet , new malossi multivar variator kit and belt gear oil change and engine oil done as well new lockset fitted just waiting on frontpanel now then bike will be ready for mot after i have sorted out the brakes as they are not working due to cracked brake pipes leaking but did not get them sorted today as leg started hurting to much Good to see you able to start tinkering again. Do all the go faster bits first. Then sort the brakes. Great minds think alike. 😂
Post by mrchilled85 on Jan 22, 2023 15:45:42 GMT -5
got out to work on the malaguti-madison 125 tho was a bit hard having to use crutches changed the carburetor to a naraku 30mm and got it running best with a 107 main jet and 35 pilot jet , new malossi multivar variator kit and belt gear oil change and engine oil done as well new lockset fitted just waiting on frontpanel now then bike will be ready for mot after i have sorted out the brakes as they are not working due to cracked brake pipes leaking but did not get them sorted today as leg started hurting to much Good to see you able to start tinkering again. Do all the go faster bits first. Then sort the brakes. Great minds think alike. 😂 yep and needed the variator tho as old one was so worn out but cant see how for only doing 15k miles and was tinkering away but after 2hrs was starting to get in a bit to much pain for trying to hold that leg up when working but turns out its not brake pipes leaking its the seals in the reservoirs and callipers so need to redo the full front and rear brakes
Post by aeroxbud on Jan 22, 2023 16:04:52 GMT -5
Good to see you able to start tinkering again. Do all the go faster bits first. Then sort the brakes. Great minds think alike. 😂 yep and needed the variator tho as old one was so worn out but cant see how for only doing 15k miles and was tinkering away but after 2hrs was starting to get in a bit to much pain for trying to hold that leg up when working but turns out its not brake pipes leaking its the seals in the reservoirs and callipers so need to redo the full front and rear brakes If you can get a rebuild kit it shouldn't be too expensive. Don't overdo it. Listen to your body. I've been there and it's frustrating. But you don't want to make it worse long term.
Post by mrchilled85 on Jan 22, 2023 16:27:43 GMT -5
yep and needed the variator tho as old one was so worn out but cant see how for only doing 15k miles and was tinkering away but after 2hrs was starting to get in a bit to much pain for trying to hold that leg up when working but turns out its not brake pipes leaking its the seals in the reservoirs and callipers so need to redo the full front and rear brakes If you can get a rebuild kit it shouldn't be too expensive. Don't overdo it. Listen to your body. I've been there and it's frustrating. But you don't want to make it worse long term. looking online and cant find any for them so may get a bit expensive as just the front and rear callipers come to nearly £150 for new ones im not over doing it i will be resting now for 2-3 days as still ment to be bed bound tho just had to get out for a bit as over a month of just looking at 4 walls
sinfull
Post by sinfull on Jan 22, 2023 18:26:09 GMT -5
Still need to finish front end, but she starts and idles 😀😀 back plastics are mismatched and sort of fit together, brakes and headlight are next. Wiring is still sketchy at best, but wanted to get it to run before I tear the bike apart and order the parts I want. Some fiberglass and some paint. But will wait for everything to actually get ordered before I actually do a full build. But she starts 😀😀😀
Post by tanto564 on Jan 24, 2023 5:33:51 GMT -5
Got a highway bar and pegs put on the Zuma. Can't wait to have my feet kicked out while I'm cruising this summer.
Post by FrankenMech on Jan 24, 2023 9:55:20 GMT -5
Airflow keeps the balls cool. One could also wear a kilt if their heritage was correct
br4inl3ss
Post by br4inl3ss on Jan 28, 2023 15:50:04 GMT -5
from this to this i know i know them wheels desperatly need a refresh.
Post by 90GTVert on Jan 31, 2023 7:39:17 GMT -5
The temp got up to 58 yesterday. Didn’t have much time, but I did get a short ride in since cold is coming. The heat woke the bugs up.
