Post by nelson on Sept 4, 2014 20:48:01 GMT -5
Your bike is not going to do 60mph if you had 2k to put into the engine. the power you need to generate to get that much weight going is not gonna happen with 50 or 70 cc and not be running on the edge. If you are worried about opening the case becauee you have minimal tools you have a long learning experience ahead of you.I think you should have more realistic goals or change your plan of action.
Post by treylaw on Sept 4, 2014 21:21:13 GMT -5
nelson i want to build a every day bike that i just have do a 20minute retune change out a part or two and to transform from a nice looking city cruiser with good mpg to a power house bike that can have a shot at winning a throphy with i want it to look like a cross between a scooter chopper and the drag racing version of both
Post by treylaw on Sept 4, 2014 21:35:48 GMT -5
the tools im working with are a cheap 23 pc metric imperial combo set with a 1/4 inch drive 3 different kinds of china made vise grips witch i mostly use as clamps the best 2 screwdrivers i have i are Stanley i gave 1.50 a pice for the rest i are hand me downs i have an impact driver but it is air powered and at my papas house
Post by treylaw on Sept 6, 2014 1:10:02 GMT -5
i think im just gonna buy a 150cc [fuck the cops the question is witch witch engine is the right one for my scooter provide links please i perfer amazon but il take any suggestions
Post by treylaw on Sept 6, 2014 1:30:32 GMT -5
Post by 90GTVert on Sept 6, 2014 7:22:20 GMT -5
If you have a short case currently, a short case would be the easiest way to go. A long case would make it look a little stretched out and can use a larger tire, but there could be clearance issues with the mudguard and it would draw a bit more attention I'd think. Short case scoots usually have 10" wheels and up to about a 3.50x10 tire. Some have 12" wheels, but they'd be very low profile. The long case can use 10-13" wheels and doesn't need really low profile 12" tires to fit.
Unless your scoot is one with two sets of engine mounts on it so either motor bolts in, you'll need to weld in a mount for the 150. Some buy used 150 scoots and chop the mount out. I'm sure they're around somewhere for sale or something custom could be fabricated.
Post by treylaw on Sept 6, 2014 13:59:48 GMT -5
the only place it mounts on the frame is where the main stand is at and where the shock is at in the rear
Post by treylaw on Sept 7, 2014 17:22:41 GMT -5
it seems the engine im needing has to have the main stand mounts below the cylinder not above. anyone have any idea where to look for this kind of 150cc engine
Post by 2TDave on Sept 7, 2014 17:52:33 GMT -5
Quote from 90GTvert:
Unless your scoot is one with two sets of engine mounts on it so either motor bolts in, you'll need to weld in a mount for the 150. Some buy used 150 scoots and chop the mount out. I'm sure they're around somewhere for sale or something custom could be fabricated. [/quote]
Post by treylaw on Sept 7, 2014 19:58:07 GMT -5
i dont have a arc welder and welding work and tools where i live is very outrageous in price. but it will be worth it to have them on hand i will send detailed pics of of the frame soon for ideas on how to im gonna fabricate a sturdy mount for this engine www.amazon.com/gp/product/B00H57PKKG/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A2YLPJX0JZGMZAit seems like i will have to buy the brake set up and wheel but i dont know what to buy i wish i knew everything about this because i think im just wasting my time trying dealing with this forum and getting no helpful answers
Post by niz76 on Sept 7, 2014 21:10:51 GMT -5
Sorry you feel that you are getting no helpful answers. It does help if you can provide pictures with your posts and they are well lit and clear. That way members can see what you see and provide suggestions/answers you're looking for. The tech section and others builds are packed full of info and in my experience you will not find a better source of info on any other site as this forum is full of knowlegable and experienced scoot members. a quote from the movie 'Jerry Maguire'; "Help us help you."
Post by treylaw on Sept 8, 2014 1:40:39 GMT -5
im needing to know what size the fuel lines are on a tpgs 824 the engine as you know is a 139qmb but i dont know what size fuel lines it uses because im gonna remove the stock vacuum petcock and add two 2 liter reserve fuel tanks and a brigs and striation switch petcock both of witch have 1/4inch nipples im also wanting fully replace the fuel lines and if your asking why im puting on two reserve tanks i say just because
Post by 90GTVert on Sept 8, 2014 9:26:30 GMT -5
3/16 and 1/4" fuel lines are on most scoots. 1/4" lines usually work, some have a smaller nipple on the carb and 3/16" works better. There were some bottom mount engines in a few models of I believe ATVs and a more motorcycle-like scooter, but I wouldn't count on finding one for sale. You or someone will most likely need to fabricate an engine mount, or at least weld a premade mount into your frame if you want a 150 to work. Katastroff just posted a few pics of a mount he made to give you ideas and there is a search link below that contains some other swaps and discussion of swaps. 49ccscoot.proboards.com/thread/10030/stroff-mobileSwap SearchFor a brake and wheel just search for GY6 brake shoes or something similar, same for the wheel. It may not work on Amazon, but lots will come up on eBay. Also if you search eBay for GY6 150 short case results come up about $200 cheaper than the engine you linked on Amazon. I know you said you'd like Amazon links, but that's a huge difference. There's a cheaper one on amazon you can find with the same search, but customer service from that seller gets bad reviews.
Post by treylaw on Sept 8, 2014 9:49:41 GMT -5
seeing that tells me im not ready for something that major it least not frame work im gonna with a hoca 4t power pack and some carb tunning fuel line rerouteing and cvt work and later on upgrade the camshaft and take what speed and acceleration i can get. at this point im just wanting to get her running once more and i dont like ebay due to poor anti fraud policy they have
Post by treylaw on Sept 8, 2014 17:35:04 GMT -5
