Post by Deleted on Sept 6, 2014 14:50:34 GMT -5
Trying to get my swap running correctly. I don't have the kick start installed currently I'm just using the electric starter and it's always engaged! It never stops spinning after the bike starts is that normal on these motors? It doesn't seem right... I looked up the starter diagram and I was missing a washer so I found one and installed it but still the starter spins. I don't get it
Post by 2TDave on Sept 6, 2014 15:53:14 GMT -5
No it's not normal and it will burn up the motor and drain your battery. Possibly burn up wiring as well. Check the switch and connections.
Post by Deleted on Sept 7, 2014 12:12:09 GMT -5
Issue solved, my starter wheel is Chinese and the flywheel is yamaha so I precision machined the Chinese wheel to better match the zuma flywheel and she's fixed!
