Post by lordaudie on Sept 27, 2014 15:39:44 GMT -5
Thank you katastroff. I guess that answers the question regarding the hose. According to the video it should be like that.
That means that I'm back at square one.
I really don't know why the scooter won't turn on/won't idle when is on.
Post by katastroff on Sept 27, 2014 15:54:06 GMT -5
Have you found where the electric plug goes?
Post by Elektrey on Sept 27, 2014 16:02:45 GMT -5
Well your not at square one, you say you have spark. You replaced carb and fuel lines so it should have fuel, and assuming the starter works and its trying to start, I would check the compression.
Post by lordaudie on Sept 27, 2014 16:09:46 GMT -5
Post by Elektrey on Sept 27, 2014 16:19:51 GMT -5
Is it just cutting out when it idles? If so try changing the idle mixture screw.
If it is just cutting out randomly could be a faulty CDI maybe?
Post by lordaudie on Sept 27, 2014 16:48:20 GMT -5
It cuts off when idle. The old carb has the mixture screw sealed. New vid with new carb. Turned the screw 360 clockwise. What's the diff between cw and ccw? www.youtube.com/watch?v=j-ZNqyOefLk&list=UUWows-6YI2zlN9q7DzUIccAThe idle was too strong so I kept lowering. At some point it just turned off when the idle was too "low". Which still had the wheel spinning to fast.
Post by iwannascoot on Sept 27, 2014 17:20:28 GMT -5
Have you found where the electric plug goes? I'm almost positive the wire/plug is a spare on his scoot. I have a 2014 Taotao with the same plug that is not used. I posted a picture in this thread. Billy
Post by Elektrey on Sept 27, 2014 17:32:44 GMT -5
have you tried playing with the idle mixture screw on the new carb?
Post by katastroff on Sept 27, 2014 17:50:08 GMT -5
Have you found where the electric plug goes? I'm almost positive the wire/plug is a spare on his scoot. I have a 2014 Taotao with the same plug that is not used. I posted a picture in this thread. Billy You must've posted it while i was posting the video, sorry i missed it.
Could be for an air conditioning unit.
Post by lordaudie on Sept 27, 2014 18:59:16 GMT -5
have you tried playing with the idle mixture screw on the new carb? I did, twice. Not much difference. Half full circle clockwise each time. What does turning it to each side means? I will continue tomorrow. Long day today. Thank you all for all your help.
Post by Elektrey on Sept 27, 2014 19:36:25 GMT -5
Turning it to the right will richen and to the left will lean. If it's too lean/rich it will not idle. Could also be the idle jet is too small/big.
Post by Deleted on Oct 8, 2014 16:44:40 GMT -5
What do you mean by low compression? intake compression power exhaust the compression stroke is one of the 4 strokes of a 4 stroke engine. 150psi to start at all and run 180 to start easy and run good 220 to start easy and run great When diagnosing ANY hard to start/no start 4 stroke scooter engine, a compression test is always first. Why? because if compression is low, nothing else matters. Compression testing is the most overlooked step in novice automotive diagnostics. The hose in the first pic is PAIR fresh air intake. it goes nowhere. The electrical plug is on all new taotaos, that wiring harness is used on a different model as well and it has some feature that yours does not, by the wire colors it looks like kick stand kill switch.
Post by jhobe6678 on Oct 8, 2014 18:01:36 GMT -5
What do you mean by low compression? intake compression power exhaust the compression stroke is one of the 4 strokes of a 4 stroke engine. 150psi to start at all and run 180 to start easy and run good 220 to start easy and run great When diagnosing ANY hard to start/no start 4 stroke scooter engine, a compression test is always first. Why? because if compression is low, nothing else matters. Compression testing is the most overlooked step in novice automotive diagnostics. The hose in the first pic is PAIR fresh air intake. it goes nowhere. The electrical plug is on all new taotaos, that wiring harness is used on a different model as well and it has some feature that yours does not, by the wire colors it looks like kick stand kill switch. My GMW/Wolf M1 has that damn kickstand kill switch. It caused me 30 minutes of GRIEF when I got the scooter home and couldn't figure out why it wouldn't start! And yeah, the PAIR system is useless to some degree. Wow, the compression on a 4t can go that high? My 2t has 160psi and I thought that was high.
Post by dudescoot on Oct 9, 2014 11:41:24 GMT -5
The first hose is supposed to be unhooked, the plug doesn't go to anything on the scooter goes to one of these But most of the Tao Tao scooters didn't come with it. Have you made sure that all the fuel lines are primed with fuel? On some of these they use the engines vacuum to draw fuel and it doesn't happen right away so make sure the carbs bulb is full and there's no blocks in the lines. Also make sure your battery is fully charged I've had problems on scooters where the starter would draw so much juice on a low battery that it would either not start or barely start then die because the battery couldn't provide spark and turn the starter.
Post by jhobe6678 on Oct 9, 2014 12:39:34 GMT -5
The first hose is supposed to be unhooked, the plug doesn't go to anything on the scooter goes to one of these But most of the Tao Tao scooters didn't come with it. Have you made sure that all the fuel lines are primed with fuel? On some of these they use the engines vacuum to draw fuel and it doesn't happen right away so make sure the carbs bulb is full and there's no blocks in the lines. Also make sure your battery is fully charged I've had problems on scooters where the starter would draw so much juice on a low battery that it would either not start or barely start then die because the battery couldn't provide spark and turn the starter. Umm. That's a flasher relay.
