Post by dudescoot on Oct 24, 2014 19:58:55 GMT -5
So cleaned my carb again trying to diagnose my scooters problems and after getting it back together I fire it up rev it up to get the vacuum going for gas to get pulled up it revs then goes straight to a very low rpm and sounds like a chopper I believe it's being flooded because if I let just about all of the throttle out it will come up to a normal idle but that's it. Everything is in the same place it was I've checked three times wtf did I do?
Post by katastroff on Oct 24, 2014 20:18:11 GMT -5
I had mine set up to run like that on purpose ( I just loved the sound of it) and I was running rich as a pig.
Post by dudescoot on Oct 25, 2014 8:53:10 GMT -5
But the problems is it won't do anything more that sound like it has a massive cam in it the TPMS won't change it's just gurgles on fuel.
Post by katastroff on Oct 26, 2014 5:33:45 GMT -5
Sounds like its way to rich. Have you tried to adjust the air screw?
Post by dudescoot on Oct 26, 2014 19:38:57 GMT -5
So I feel dumb, I forgot to put the cap back on the needle to keep it from just coming up and not going back
Post by katastroff on Oct 26, 2014 19:47:41 GMT -5
Don't beat yourself over this, we all make mistake.
I got married twice. Luckily, I lived to tell about it.
Post by scooterpimp on Oct 26, 2014 20:19:40 GMT -5
Its only dumb if we dont learn from our mistakes!
Post by katastroff on Oct 26, 2014 20:27:51 GMT -5
Its only dumb if we dont learn from our mistakes! Don't rub it in.
Post by Fox on Oct 26, 2014 21:18:16 GMT -5
I have done the same thing. I have done a lot of other stuff in the same vein as well like install the cap on the diaphragm and forget the spring, hooked up batteries backward several times, installed variators without roller weights, try to start a scooter after cleaning the carb and realized I didn't tighten the fuel drain etc...
Post by moofus02 on Oct 30, 2014 6:26:41 GMT -5
Don't beat yourself over this, we all make mistake. I got married twice. Luckily, I lived to tell about it. Married 3 times lol i even put a float in upside down once Sent from my SPH-L720 using proboards
Post by jhobe6678 on Oct 30, 2014 8:17:53 GMT -5
I haven't been married yet. Can't say I didn't make stupid mistakes in life though... Paying for one now hah.
Post by stevec on Oct 31, 2014 20:39:08 GMT -5
i was married twice, i won't take the chance on third time is the charm. i was recently working on a scooter and was going crazy trying to figure out why it wouldn't start, after some time passed and a lot of checking i noticed the kill switch was set to off, it ran fine once i fixed that problem. i had one that i worked on forever trying to figure out why the petcock wasn't working and hooking the line up direct to the carb didn't work before checking the empty gas tank. we all make mistakes, they are learning experiences and some are even worthy of youtube like the ones i make.
Post by katastroff on Nov 1, 2014 4:21:41 GMT -5
After getting stranded about a dozen times with no clue of what the problem was, I decided to remove the kick stand kill switch...
Post by jhobe6678 on Nov 1, 2014 4:24:31 GMT -5
I'm not too far off from that myself. Why the hell did they even put that thing on there!!??!?!
