Coil?
Oct 25, 2014 18:36:18 GMT -5
Post by dirtyharry on Oct 25, 2014 18:36:18 GMT -5
I started my scooter it warmed up, throttled down but tried to bog down when i gave it gas, i messed with the coil, both ends and it started running good, i will not mess with it until the new one gets here, does this sound like a legit problem or could something else be going on, i have a coil andcdi box on the way.
Coil?
Oct 25, 2014 19:35:11 GMT -5
Post by scooterpimp on Oct 25, 2014 19:35:11 GMT -5
What does messed with both ends of coil mean? Loose connection , plug cap issue?
Coil?
Oct 25, 2014 20:25:46 GMT -5
Post by niz76 on Oct 25, 2014 20:25:46 GMT -5
The coil wire just screws into what basically looks like a drywall screw for the connection. Screwing it on tighter/better could very well be a legit solution.
Post by dirtyharry on Oct 26, 2014 6:09:31 GMT -5
The 2 connectors one end i crimped a little tighter, the plug end i just, unplugged and replugged it and it is running fine now drove about 20 miles no problem i did not try tightning the boot, will do so if it starts acting up
