Post by renners on Nov 16, 2014 14:57:51 GMT -5
Well folks, So the dash on my scoot isn't working (speedo cable = wanked) but no tacometre no oil light no petrol gauge. The ignition is gone in this bike So its start with a kick. Headlights work like this. *no other lights work(brake,indicators) Battery seems to be wired incorrectly
Sorry if this isn't enough info I'll try get pics up tomorrow
Post by Sitticuss on Nov 16, 2014 21:02:26 GMT -5
fuse?
Post by katastroff on Nov 17, 2014 10:15:12 GMT -5
Its either that or you got a connector that came loose. But check the fuse first, easy to check and fix.
Post by renners on Nov 17, 2014 14:37:33 GMT -5
all electrics are located in the front fairings ?
Post by Clank on Nov 17, 2014 15:20:48 GMT -5
If there's no ignition then you have an open circuit. You'll need to make a jump where the ignition was. All the power runs through your ignition before distributing to other electrical except the headlight & cdi. This might help. Also note that there is a harness in the front for a optional alarm & remote starter. If the jumper wire is removed that to would cause an issue
Post by katastroff on Nov 17, 2014 18:22:29 GMT -5
all electrics are located in the front fairings ? Yep.
Post by renners on Dec 7, 2014 16:51:18 GMT -5
Hi, So I've been really busy with school lately but I've been digging about in the front fairings and can find any fuses/fuse box. I checked all connections and they seem to be in place. The battery has two very small gauge cables attached which I followed up to the ignition coil/relay. I'll try and get pictures up tomorrow but I'm back at school so no promises
